Why Delete AFM ..... stock cam
Old Dec 18, 2010 | 02:38 PM
  #21
1Bear's Avatar
I guess that means you just need to have a spare ECM and cluster that you swap in tandem.
Old Dec 19, 2010 | 07:16 PM
  #22
CDN SS's Avatar
Thanks for the info , it all helps
Old Dec 20, 2010 | 01:29 PM
  #23
cam's Avatar
cam
I havent read much about lifter "failures" per se but there are TSB's out there for "over active lifters" and the more important issue and main problem with the AFM crap "Oil consumption" problems. IIRC the replace/no replace threshold is one liter per thousand km's of use so about one quart for 800 miles. Thats insane IMO and enough to scare me away. There are also issues with piston rings becoming so caked in burnt oil deposits that they stick and the engine loses compression.
The actual lifter issue is the least of your worries with one of these AFM engines.
Old Dec 21, 2010 | 01:54 PM
  #24
JAVI05's Avatar
i am having the dry start problems.. im gonna take it in the new year... to replace lifters. i wish i could tell them to put some ls7 lifters and disable that crap..
Old Dec 23, 2010 | 03:33 AM
  #25
ZXSSMAX's Avatar
Hell yea for a mass produced lifter like the LS7 they might as well give you the choice of of which ones you want. Esp if you have to deal with this problem to begin with. I wonder GM's cost on the AFM lifters compared to da LS7's???
Anyways good to know that my lifter tick that i was hearing is due to the AFM/VVT bullshit and now i finally have a solid reason to do a cam swap with some well needed valvetrane upgrades.
Anyone know of any GM service writers at a chicago land area GM dealer that would be able to see if they will relpace the AFM lifters with some LS7s under warranty???
Old Dec 23, 2010 | 09:33 AM
  #26
CDN SS's Avatar
Has nothing to do with VVT .thats a good thing
Old Dec 23, 2010 | 10:32 AM
  #27
Robert91RS's Avatar
Cant be done unfortunatly. You are on your own on the delete.
Old Dec 23, 2010 | 07:39 PM
  #28
CDN SS's Avatar
OK guys if I decide to install a DOD kit on my new truck LC9 5.3 but plan to keep the stock cam and VVT ...........all I need to do is pull intake / valley cover and heads and swap out the lifters and valley cover .correct ? dont need to pull the front cover etcetc
Can you tell I never had a LS motor apart
BTW is the oil pump different on a DOD engine ???
Old Dec 24, 2010 | 08:40 AM
  #29
Robert91RS's Avatar
-Yes
-Yes but you'll do fine.
-No. Same part number pump as everything else.
Old Dec 24, 2010 | 09:52 AM
  #30
CDN SS's Avatar
Originally Posted by Robert91RS
-Yes
Thanks ......I got it now
