what size headers?
Old May 13, 2010 | 03:32 PM
PathfinderJr's Avatar
With a big-*** crew cab, I'd stick to 1-5/8" headers even with a mild cam unless you are gonna slap a decent size stall in there, cause then you can flash right past the lack of low-end. In that case, 1-3/4" will be fine.
Old May 13, 2010 | 03:59 PM
markislive78's Avatar
13 Second Truck Club
Look at it this way... every 1/10th gained in your 60' is usually worth 2/10th's at the end of the 1/4 so bottom end is a huge factor...
I had a Nissan Titan in 2004 cutting 1.9 60's on 20'' wheels w/Headers, Tune, Intake, Exhaust (14.07@96mph) it was all bottom end in that truck (5.6) Headers were 1 5/8'' w/2.25'' Y to single a 3''.
Old May 13, 2010 | 04:02 PM
To bad he doesn't have a big selection to chose from w/1 5/8''...If you do go 1 3/4 stick with a single 3'' out
Old May 13, 2010 | 04:08 PM
skoal bandit's Avatar
i already have a 3000 stall to help on bottom end. i will eventually replaced the chokemaster with a 24" magnaflow 3" in 3"out. and not going duals either
Old May 13, 2010 | 04:29 PM
Here are the one's I've owned, both 1 3/4'' I ended up returning the Kooks for the AR's
AR pic's are 1st, last 3 are Kooks... Kooks Y has dual 3'' merged into a single 3'', the AR Y-Pipe is a little more open with a 3.5'' outlet
Attached Thumbnails what size headers?-headers2.jpg   what size headers?-headers.jpg   what size headers?-untitled-9.jpg   what size headers?-y-pipe2.jpg   what size headers?-untitled-1.jpg
Old May 13, 2010 | 04:30 PM
iamkeniff's Avatar
my CC is 14.4 @ 94.89mph
go 1 3/4" unless you get skipperdaddys for cheap, just my .02
i would stay away from the 1 7/8" unless you went 6.2 or bigger with FI or a cam/Nitrous set up
get with Pat G an he'll spec the perfect cam for you. if i dont get 12.99s out my cam im going with a Pat G cam for mid to high rpm with a 3400 stall
Old May 13, 2010 | 04:46 PM
What kinda 60' times are you cutting with that stall?
Old May 13, 2010 | 06:28 PM
iamkeniff's Avatar
stock 3:42s/G80/265-70-17s i have a best of 2.0 60' with it stalled to 2500rpm anything over that it blows the tires and i cant recover
Old May 13, 2010 | 06:30 PM
iamkeniff's Avatar
https://www.performancetrucks.net/fo...d.php?t=457957
theres the link to my time slip
Old May 14, 2010 | 12:00 AM
damn it... i like roll racing... yall making this **** confusing... 1 3/4" with the stall or what?
