What has been your warrenty issues?
#23
Both door lock actuators went in the same week...not too long after I put on keyless handles thinking "what are the chances both door locks ever fail at once". Besides having to jimmy in, it was actually pretty funny. No questions asked at the dealer, said they've done several.
08 silverado ecsb
08 silverado ecsb
#24
1. I was getting the "Service Stabilitrak" idiot light, turned out to be a bad steering wheel position sensor.
2. Plugged sunroof drain.
3. There was also the recall for the heated washer fluid system.
...And that's it.
...And that's it.
#25
at 38.5k ive found that my rear seal is leaking again, or something of the sort. its bs that roughly 20k ago it happened an now again? wtf im starting to regret my new truck more and more! i wish i woulda kept my 01 it had 83k on it an it never had a problem!
#26
Took mine in for what I thought was an air conditioner leak. Turns out my third brake light was leaking behind the lens. Which allowed dew to come in, run down the back of the cab, and soak the driver side front/rear carpet. Hopefully the carpet is not moldy, because I'll take it right back. So if your carpet is wet, check the brake light.
other than that ive never had an issue with my 09 @25k miles. well other than its a TURD!
#27
i have noticed some condensation in the 3rd brake and my carpet is wet as well. also looks like water marks running down the INSIDE of the rear window. guess ill have to check that out.
#28
Mine was the same issue.. Took out the third brake light.. the sheetmetal section that actually holds the third brake light down is really thin.. when installed at the factory they overtorque the fasteners and bent the sheetmetal.. the seal wasnt even contacting the roof panel.. Poor design in the first place.. but worse when they dont assemble it properly.. I made two tabs and epoxied them into place under the sheetmetal.. then i allowed that to dry, drilled a small hole in the now 3 times thicker metal and attached the third brake light with the factory fastener.. Then took a hose laid it on the roof and checked for leaks everywhere.. Good to go.. Gotta be better than what they will do at GM.. My local dealer said there isnt any issues with it so they didnt have a fix and would charge me to look at it..
#29
Battery and factory CD player replaced under warranty at about 25,000. Wanted to look at brakes, but figured they would screw me into paying. Just kept driving. 70,000 miles on it now. Three factory door speakers blew, but I just replaced them with some infinitys. Really been a pretty good truck so far.
