what do i need 5.3 to 6.2..
Old Feb 9, 2009 | 11:02 PM
sand man's Avatar
Exclamation what do i need 5.3 to 6.2..
hi. im new here and i have alot of Qs...
first:
is the new 5.3((2007+))a 4 or a 2 main bolt
second:
do i need to change the hole block or just the cylindrs and heads..
why:
i am gitting a 2009 sierra or silvy 5.3 crew cab short bed with the 6l80e do i need to upgrad the tranny to hold the 6.2 400+hp((we dont have the vmax or the 6.2 and we cant order them too ))...will it hold the power or just crack up like the 4l60e..im an off road guy and i am from saudi arabia so i need the truck to be tuff as hell with my 100+miles in the desert with no roads...will the 4WD TCase take this power..
i want to do all that cause the tundra is coming to us in 2010 and i hate to be beaten by a toy
Old Feb 10, 2009 | 11:00 AM
Z06.0's Avatar
your transmission will be fine, its the same one that comes with the 6.2, as far as the engine mods go, i have no idea
Old Feb 10, 2009 | 11:03 AM
nighthawk08's Avatar
you'll want to get the whole engine and intake manifold. I believe you'll need a new wiring harness because the 6.2 has VVT and the 5.3 doesn't.
Old Feb 10, 2009 | 11:48 AM
Allgonoshow's Avatar
what are you intending to do, order an engine from usa and install it?
new or used,
a used 6.2 may be hard to find.
get the whole engine , pcm, harness , which ever way you do it.
why not put a tvs1900 on your 5.3, you'll get good power WAY WAY easier
Old Feb 10, 2009 | 12:02 PM
cbenavides06's Avatar
Default swap
My cousin had a 2007 4.8l in his truck. He pulled it out and installed a 6.2l with no problems. same wiring, sensors, and etc....
Old Feb 10, 2009 | 12:06 PM
chevrolade's Avatar
You can use same ecm harness,trans,plug ins etc.the 6.2 is a 6bolt main.get the complete 6.2
Old Feb 10, 2009 | 04:09 PM
viciousknid's Avatar
Where's the Beef?
I do believe that ALL LSX blocks are 6 bolt main. But as stated, use the entire engine.
Old Feb 10, 2009 | 11:04 PM
sand man's Avatar
IF WERE To CHANG IT ILL BE TAKING THE ENGINE FROM A JUNK YARD
so you say i dont need to change the wiring and the ecu??
cbenavides06
moer info please
Old Feb 11, 2009 | 05:28 AM
Denali Dude's Avatar
the Wiring and ecu off the 5.3 will work U will need the engine and the intake manifold thats it. Im waiting for my engine to arrive then IM gonna TVS that thing
Old Feb 12, 2009 | 11:52 AM
Default ecm
Yes it will work. You do need the longblock with intake. He had it put in overnight and tuned the next day it runs real good.
