vvt deleters, enter here
Old Oct 29, 2011 | 11:04 PM
Area47's Avatar
Default vvt deleters, enter here
im gathering a parts list to do a cam swap. so far i have the following
front cover
cam gear
bolts
wp gasket
fc gasket.
so i need to change the cam sensor, and the harness?
Old Oct 30, 2011 | 11:54 AM
Area47's Avatar
since the lack of replies has led me to believe that i have all the parts needed.
Old Oct 30, 2011 | 04:59 PM
rice eater 03's Avatar
im curious why you wanna delete the VVT? with some of the newer VVT cams out now it seems like you would wanna take advatage of lower end power to be made, unless your going with a really large stall or something were that isnt an issue.
Old Oct 30, 2011 | 06:02 PM
Area47's Avatar
i pulled my hair out enough doing work on the stock vvt tables with the stock cam. i really don't want to deal with more tuning crap.
the cam swap i want to do will still have low end torque, and cost less than a vvt cam by itself, not counting the cost of the phaser kit on top of it.
Old Oct 30, 2011 | 06:43 PM
silver-mod-o's Avatar
Hunt&Fisherator
https://www.performancetrucks.net/fo...delete-471525/
Old Oct 30, 2011 | 07:28 PM
pl4yboy's Avatar
Banned
Originally Posted by silver-mod-o
LS2 Timing cover, cam sensor, cam bolt, cam sprocket (to fit single or 3 bolt). That's it. I have part #s if you need them. Please make sure your timing cover has a front crank seal in it. Mine didn't and I didn't find out until I had it on.
Old Oct 30, 2011 | 08:01 PM
Hunt&Fisherator
Not sure why you quoted me lol but I posted a link to my thread with all the info you need to make it happen
Old Oct 30, 2011 | 10:07 PM
Area47's Avatar
part numbers would be awesome! i have searched for 2 days so far on various lsx forums, and part numbers seem to be illusive.
Old Oct 30, 2011 | 11:44 PM
pl4yboy's Avatar
Banned
I was on my phone and just clicked reply to the last post.
12585673 GM LS1 CRANK SEAL
12591689 GM SINGLE BOLT CAM SPROCKET
12600326 GM LS2/LS3 (Non V.V.T.) FRONT COVER
12591720 GM LS2/LS3 CAM SENSOR
11561283 CAM BOLT (FOR SINGLE BOLT LS- CAMS)
Keep in mind this is for single bolt setups. Also, I am not positive on the part number for the crank seal. I'm not sure if LS1 and LS2 covers take the same seal. I would bet they do. This is literally all you need. I didn't replace a single gasket and have almost 2k miles with no leaks at all. Let me know if you have any questions regarding this. I did it around three weeks ago, so its pretty fresh on my mind.
Old Oct 31, 2011 | 08:19 AM
Robert91RS's Avatar
Timing Cover Gasket-12633904
Water Pump Gaskets-12630223 (x2)
3 Bolt Cam Sprocket-12586481
LS2 Chain Dampner-12588670
Cam bolts-12556127 (x3)
Cam sensor is the same and wont need to be changed.
