Trying to pick out a cam
Old Nov 9, 2010 | 04:35 PM
  #61
Daryn's Avatar
Formerly darynC-10/23/10
i would only go with extremes if you have a larger cam or trying to spin to the moon. a cam with a low lift dont really need a spring with gobbs of spring pressure thats what kills lifters
Old Nov 9, 2010 | 05:49 PM
  #62
Mrgoodwrench3's Avatar
Well I am running Scorpion Racing 1218 springs. Same specs as PAC. So far no problems. But I also checked installed height and pressures.
Old Nov 9, 2010 | 10:54 PM
  #63
iamkeniff's Avatar
no ones talking about low lift cams hommie. the .500-.535/.540 cams i would run a LS6 spring, if i run close to .600 i will run a patriot dual valve spring. nothing wrong with an extra spring rated for more imho. id rather have over kill vs not enough and run on the line of "will these springs hold up or not"
Old Nov 9, 2010 | 10:59 PM
  #64
Daryn's Avatar
patriot has the golds and gold extremes golds are .650 and extremes are.650 im talking about a cam thats has .600 or less homie
Old Nov 9, 2010 | 11:12 PM
  #65
iamkeniff's Avatar
now we on the same page
no anything below .580 i wouldnt run a .650-.660 spring on. PAC has a spring rated for .600 right? wayyy better than the 918s if i remember correctly.
anything below a .540 lift id just run a LS6 spring.
i seen a few cams id love to run and they are on a 115-117 so they'd be sneaky as hell
Old Nov 9, 2010 | 11:28 PM
  #66
grey matter 04's Avatar
13 Second Truck Club
sneaky like a low lift 212/218
Old Nov 9, 2010 | 11:46 PM
  #67
Daryn's Avatar
PAC was the original manufacturer of the 918. but when comp switched manufacturererers , they went to crap...... pac' still makes thier own behive spring. which i would run on a cam like a 224 with a lift of .560ish... but why not run a dual spring.."its safer" i bought my patriot kit for 250$
Old Nov 10, 2010 | 07:40 AM
  #68
blk08chevy's Avatar
What do yall think of this cam? 218/222 .595/.597 111 LSA do you think that would be a good cam for my truck? and what springs would you run with this cam?
Old Nov 10, 2010 | 11:19 AM
  #69
iamkeniff's Avatar
like i said itd be nice.....better get ready to run a 3200 converter/4:10s/full exhaust/cai/ud crank pulley/good tune. that 111 is going to suck as a DD if its not tuned right
run the patriot .650 lift imo.
Old Nov 10, 2010 | 11:27 AM
  #70
blk08chevy's Avatar
would my 3000 stall be good or should i flash it at 3200?
