Truck smells like antifreeze under hood
Old Feb 3, 2014 | 08:13 PM
JRENIGAR's Avatar
Default Truck smells like antifreeze under hood
The truck in my sig has a very noticeable smell of antifreeze from under the hood when running and I have looked for a leak but no luck. It gets parked on concrete and dosent leak anything on the ground ever. I have to add about 1 inch of coolant into the recovery tank every couple of hundred miles or so. It isnt smoking white and runs fine. The oil isn't milky and I have replaced the reservoir cap already. Before anyone tries accusing me of I have done a search. Any Ideas?
Old Feb 3, 2014 | 09:45 PM
AUTOT3K's Avatar
do you have access to a pressure tester?
Old Feb 4, 2014 | 07:40 AM
JRENIGAR's Avatar
I can rent one from the parts store if that's what kind of pressure tester your talking about. I also have a shop air compressor with an adjustable regulator and an extra overflow reservoir cap that Id thought about making into a pressure tester but unsure if that's as accurate as one form the parts store.
Old Feb 4, 2014 | 08:38 AM
GMC93's Avatar
Can you check the weep hole on the bottom of the water pump?
Old Feb 4, 2014 | 08:56 AM
kyle's v's Avatar
My 04 denali was doing the exact same thing for months until last week I found the leak. Like the guy above mentioned check the water pump that's what was wrong with mine.
Old Feb 4, 2014 | 04:36 PM
RICEETER's Avatar
i've been having the same issue with my s10 for 4 and a half years now (and has over 300,000 miles). it has a cracked head gasket but not enough to hurt anything. the only thing is that i have to add coolant every couple weeks or so but no biggie. as long as it keeps running, i'll keep driving.
anyway, the way i found it was under the truck. the coolant runs down the bellhousing of the tranny (leaving a green trail) while the truck is moving. and then doesnt leak at all when it's parked. good luck and hope this helps.
Old Feb 4, 2014 | 08:57 PM
AUTOT3K's Avatar
the home made sounds like a good idea haha, but unless you can accurately measure the pressuring leaking down then I'd rent the real one
cause once you pump it to 16psi, close the valve and now the system is sealed. get on the ground, look up the front of your timing cover and try see the bottom of the water pump area, sometimes you can even see the residual dried there. take a look around the head gaskets area, for the back of the heads its easier to see from underneath looking up from the trans bellhousing.
after you spend some time visually looking, when you come back up...see where the pressure tester is, if after 5 minutes its already dropped to like 10PSI and no visual leak found...I'd suspect internal!
Old Feb 5, 2014 | 03:52 PM
JRENIGAR's Avatar
Ill check the water pump. I also was thinking maybe the crossover tubes might have a leaking o ring on the back side of the heads behind the intake but havent been able to check yet.
Old Feb 7, 2014 | 11:43 PM
AUTOT3K's Avatar
I know on my 799's the rear cross over ports were rivet sealed from factory, so yours might be the same
Old Feb 8, 2014 | 06:33 AM
JRENIGAR's Avatar
So no crossover tubes with bolts and an o ring seal like the ls6 cars had? You say they were riveted? I will have to check into that. Thanks.
wrb002
Aug 31, 2015 12:00 PM
black00chev
Jul 31, 2015 04:33 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
