Time to upgrade
Old Nov 9, 2012 | 06:42 PM
blackvmax07's Avatar
Default Time to upgrade
ok guys to catch you up if you dont know i have a full bolt on vmax(6.0) with a fully built 4l70 with 3200 converter. Well as of 2 weeks ago iv blown my 3rd fully built trans and its snapping the output shaft in half. Trans guy said i need a 4l80, so my question is is there a specific year of trans housing i want? And wat exactly do i have to do to make it work like stock on my nnbs? thanks guys
Old Nov 9, 2012 | 07:54 PM
iamkeniff's Avatar
Id look for an 03+ and throw a shift kit in it.
You may have to do a segement swap, unless you can do the relay trick to stay on your 60e tune.
Redo the trans crossmember, extend 1 trans line (i say use 3/8" compression fittings into steel tubing vs rubber hose)
You may need to shorten the dshaft, i am not sure on that one
Old Nov 9, 2012 | 09:57 PM
ok, wats a segement swap?
Oobray
Jun 13, 2022 03:38 AM
OHsixLS3
Dec 27, 2016 09:30 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
