TBSS map in nnbs??
Old May 8, 2016 | 11:44 AM
10 Second Club
Originally Posted by Wolftrk99
My 99 wouldnt read the newer style map sensor even with the harness, wouldnt go into wide open fueling.... What year is your truck??
Do you have the stock 99' ecm? I have a 2001, wonder if it will play nice?
Old May 8, 2016 | 11:47 AM
10 Second Club
Originally Posted by TAPyvehc93
You are doing the complete opposite of me. I am trying to get a nbs/tbss map to work on a nnbs. That connector wont work for me...
I am wondering if you can just drill the hole slightly larger for the NNBS sensor?
Old May 8, 2016 | 12:12 PM
TAPyvehc93's Avatar
I really would rather not do that. Much rather just cut and solder on the new pigtail if possible. Plus the hold down strap for the map is different on the nnbs.
Old May 8, 2016 | 12:32 PM
Wolftrk99's Avatar
I have the stock map sensor run off the small vacuum port on the side of the intake, all it has to do is see vacuum... I am running the 99 ecm.
Old May 8, 2016 | 12:35 PM
Wolftrk99's Avatar
Try a smaller oring on the sensor, i know the nbs style map is smaller but i tried the newer bosch style in my nbs intake and it fit quite snugly i might add, but i couldnt find a way i liked to get the nbs sensor to seal tight enough in the nnbs intake....
Old May 8, 2016 | 01:02 PM
10 Second Club
I am going to look for a spot and drill a hole the same size as my 01' intake. I'll use the other sensor in the front as a plug for the hole.
Old May 8, 2016 | 04:18 PM
TAPyvehc93's Avatar
After a little more research, it looks like they changed to the newer style maps sensors (ones with the green o-ring) in 2009. The 2008 and older nnbs/tbss still uses the older style map sensor with the orange seal. I would "assume" the 2008 nnbs and 2009 nnbs still have the same ECU so I would "assume" the I should be able to cut of the nnbs map connector and then solder on the correct connector to my harness for the 2008 nnbs/tbss map.
lxcoupe
Apr 20, 2016 11:15 AM
2KRedSilverado
Apr 14, 2016 08:12 AM
parks450
Apr 11, 2016 05:21 AM
jbaum02
Apr 10, 2016 09:39 PM
AkSSS
Apr 10, 2016 10:17 AM
