Tach options
Tach options
The stock tach only goes to 6k, and my truck doesn'tshift aautomatically when I have it pulled down. So Ineed an aaftermarket tach that goes past 7k. Is there any plug and play harnesses out there?If not how would I hook one up?
This would be really cool in a NNBS Cluster ^
Or you can install an aftermarket tach in a gauge pod or pillar pod. You can pull your tach signal from the cluster wiring and the gauge will only need power and ground and power from the headlight switch(or any source of power with the headlights on) for illumination.
I don't have tu/td on my truck
Would the aftermarket tach read/pick up past 6k if I sourced the signal from the factory tach? I wouldn't need to pull signal from ignition source or coil pack?
I'm amazed nobody has come out with a plug n play harnesses for aftermarket tach!
You'll still need your standard fused 12v and ground but for the rpm use the factory signal!
