Strength of factory 10-bolt?
Old Apr 6, 2010 | 11:53 PM
Gregory's Avatar
Question Strength of factory 10-bolt?
Anybody know what the power limits are of the factory 10-bolt rear differential? I am considering adding a STS rear mounted turbo to the truck for towing and just a little fun, but certainly don't want to break anything. Calculations show I'll end up with approximately 460 wheel HP and a similar amount of torque.
Old Apr 6, 2010 | 11:55 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
yeah, weak. You will probably be ok if your not planning on heating up some slicks.
Old Apr 6, 2010 | 11:58 PM
fastnblu's Avatar
Seeing that your GTO is modded, u understand the go fast game: Pay now or later.
Get a Truetrac or similiar upgrade on that factory diff & be done. Based on current info.
Old Apr 7, 2010 | 12:29 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Upgrade the differential to an Eaton or Tru-Trac, put a T/A girdle on it, and you'll be just fine.
Old Apr 7, 2010 | 11:22 AM
nonnieselman's Avatar
my 10bolt has 215k miles on it, new bearings when i put the Eaton LSD in 65k miles ago.
Still kicking just fine, im in the process of taking my STS kit off, but on 6psi and 50 shot it made 440rwhp and 540rwtq. Its had a hard life and i towed alot with it.
Just get a good Diff and your golden.
Old Apr 7, 2010 | 11:23 AM
TXsilverado's Avatar
like mentioned. switch out the carrier and your golden.
Old Apr 7, 2010 | 11:24 AM
like mentioned. switch out the carrier and you're golden.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
CD82
Oct 23, 2015 07:32 AM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
Closer_2001
Sep 24, 2015 09:15 PM
