Stepping down on my cam
Old Jul 11, 2012 | 10:37 AM
Gus 82's Avatar
Default Stepping down on my cam
Current cam is a bit big and since I do some decent towing I did not want to go any higher on my stall. I did have a 219/228 .550/.550 with 114, thing sounds like a race car but in a ext cab 4x4 with 32's and 3.42 its a PIG off the line and really doesnt pull that much better up top. I just ordered a custom grind 210/224 .556/.568 112 + 5 based off comps recommendation. Putting it into a older version of desktop dyno looks like it gives me some more torque but now I am starting to think I should of ordered the 206/212 cam......
Old Jul 11, 2012 | 11:09 AM
drummer0415's Avatar
i hate to say this, but buying a 5,000+ lb. pound truck with a 4.8 was your first mistake, Lol. I agree though that you will benefit from a different cam. I would recommend having someone like Patrick G spec a custom cam for your specific setup and what you intend to use it for. The 4.56's you mention in your sig will help alot though. I would recommend installing those, and then decide if you want to go through with changing the cam.
Old Jul 11, 2012 | 07:50 PM
iamkeniff's Avatar
Why in the hell would comp spec a 14* split in a N/A 4.8?
Old Jul 11, 2012 | 08:25 PM
Gus 82's Avatar
Not sure But these are the grinds they recommend to me and after talking to several people there they said the smaller duration version with the lower LSA and 5 degrees of intake advance would be best.
HYDRAULIC ROLLER − Excellent
responsiveness and low end torque with
good power gains. 210 224 .556 .568 114°
Hydraulic Roller Camshafts (Small Displacement or Max Torque, 4.8L-5.3L)
HYDRAULIC ROLLER − Very strong torque
and excellent response. Works best in
heavy vehicles, low rpm applications. 215 233 .604 .610 112°
Old Jul 11, 2012 | 09:14 PM
Byrdman11's Avatar
Boost that bitch!!!
Old Jul 11, 2012 | 09:30 PM
Gus 82's Avatar
Ya definitely going to throw a turbo on it. I will be going rear mount and will most likely do it next year with a Comp oil less turbo.
Old Jul 12, 2012 | 12:09 AM
iamkeniff's Avatar
Since you tow often why not just slap a tvs1900 on it with a pat g boost cam?
Old Jul 12, 2012 | 01:59 AM
62nalide's Avatar
all i can say is that these 4.8L crewcabs aint no joke with the right setup, my buddy's 4.8L CCSB is running better than my old 6.2L setup NA
Old Jul 12, 2012 | 06:24 AM
Gus 82's Avatar
Once I get the cam in I will go from there. I am actualy hoping the new cam will give me a better then stock bottem end and I can exchange gears for a hwy friendly 4.11. I did my cam and converter at the same time but I think mt stock cam with my current stall would of been leaps and bounds better than it is now. I looked at a TVs1900 for a whiles since it adds under the curve power but ice built 6 or so turbo cars with great results. New cam should be shipping soon. I'll keep it updated
ARC
57
Feb 21, 2022 10:54 AM
fastjweb
Aug 15, 2015 10:47 AM
bighouse
Aug 14, 2015 08:00 AM
hirdlej
Aug 10, 2015 10:51 PM
