Which servos with 3200 stall?
Ok, my 3200 circle D will be in today but before I put it in I was wondering if I should get the regular corvette servo, the billet second, or the billet second and 4th set? I hear the billet servos are kinda harsh at part throttle, but I was thinking that with a converter this loose it would soften up the part throttle harshness?
I am installing my 4.11 gears before hand, so I got a little time before it goes in to get what you guys think would be best,lol
Vette servo with billet 4th works fine unless you want the billet 1-2 and the billet 4th theres no complaint here with either set. I ran the circle d 3200 with a vette servo only and it was plenty for me. The transmission just didnt like the extra HP i added.
You can adjust how the part throttle shifts are, its pretty easy if the tuner knows what he's doing. Only issue is having too much pressure on your WOT with the bigger servo it causes the tires to chirp = abusive on your transmission/driveshaft/rear end
