Removing stock blocks
Old Mar 21, 2013 | 07:49 AM
NightmareTBSS's Avatar
Default Removing stock blocks
When removing stock rear blocks on a '12 silverado, do you have to get aftermarket U bolts or will the stock ones work?
I didn't know if the threads would reach once they were removed.
Old Mar 21, 2013 | 08:07 AM
Chevy_King1500's Avatar
iirc, No. I put a 4". drop on my dads trucks about a year ago and I think I just used shackles and removed block. but I've slept since then
Old Mar 21, 2013 | 10:39 AM
97aztecgt's Avatar
Mine was close, but I had 2-3 threads left.
Old Mar 21, 2013 | 10:42 AM
Smitty's '04 GTO's Avatar
I removed my block and re-used stock U-bolts with no problems.
Old Mar 21, 2013 | 10:52 AM
Three6GMC's Avatar
Same here I have done it on 3 different nnbs trucks from 2wds to 4wds and just kept the stock stuff with no issues at all.
Old Mar 21, 2013 | 11:57 AM
skoal bandit's Avatar
mine didnt seem to tighten up all the way. But i cant remember what i ended up doing to fix it. I put a flip ki on since then. I think Skipperdaddy bought shorter u-bolts for his.
Old Mar 21, 2013 | 03:50 PM
splinter's Avatar
I used shorter hardware..
Old Mar 21, 2013 | 04:34 PM
SLCviaAK's Avatar
I just put some extra washers between the nut and the lower u bolt plate when I removed my blocks. I wanted to MAKE SURE I had enough thread. I will eventually put the factory NBS 2wd u bolts on. That is the 15002781 part number.
Old Mar 22, 2013 | 10:44 AM
07vmax1500's Avatar
x2 on adding washers, thats all i did i think i used 4 or 5 per stud iirc. box of washers is cheaper then new bolts, unless yourdead set on factory appearence.
Old Mar 22, 2013 | 11:04 AM
smokeshow's Avatar
Mod with training wheels
Same. I rattled the nuts on and they ran into the end of the thread on the bolt. Used some washers and it worked fine.
