Rebuild the 6l80 or 4l80 swap
Old Feb 17, 2017 | 09:31 PM
Carp's Avatar
Originally Posted by Wolftrk99
Unless there was more than what i am seeing in the pan, check the valves in the valve body, and the screens on the tcm, may have a blown screen causing at least part of the issues. But agree with everyone else, 4l80 is a downgrade in that truck, unless youre planning on a ton of power, rebuild it and keep going!!!
what do u mean by screens in the tcm. It says shift sylenoid A "performance shift solenoid stuck off" . Before I changed the fluid and filter it said all of them were stuck off
Old Feb 17, 2017 | 09:36 PM
Wolftrk99's Avatar
You would have to separate the tcm from the valve body, remove the seal plate and there are membranes or screens on each solenoid, if they blown out it messes with the pressures and typically throws codes... and metal can get into the tcm through them!
Old Feb 17, 2017 | 09:56 PM
Carp's Avatar
that kinda makes sense. I've been reading these forums and I still feel like I learn something every time. I grew up on manuals
Old Feb 17, 2017 | 10:05 PM
Carp's Avatar
thanks for the suggestions. I might as well pull the pan and valve body and check. If I can fix my trans cheaper just cuz some dummy didn't change the filter that'd be awesome. I could totally buy a cam and valvesprings tune and maybe nitrous for the price of a trans. But I guess u can't build a tree without a trunk
Old Feb 17, 2017 | 10:55 PM
Wolftrk99's Avatar
The three rings at the bottom with the bolt between the two are the membranes... had to dig this pic out of my thread... somehwere around page 33 or so!!!
Old Feb 21, 2017 | 03:00 PM
Carp's Avatar
Well thanks for the digging. So basically pull the pan again and dig a little further. I mean if the clutches are good they're good right. It just messed up almost all at once and the trans temp fully warmed up is like maybe 165
Old Feb 21, 2017 | 04:26 PM
Wolftrk99's Avatar
If it was all at once it may be a sticking valve or two in the valve body
