Question on 2009 Trucks
Old Aug 27, 2009 | 04:11 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default Question on 2009 Trucks
Question:
So, I see that you can get the VMax which is the L76 6.0L AFM and VCT. Avaliable in 1LT and in CC or EC. I currently have an '08 VMax Z71. But, the idea of the 6L80 has been making me thing about trading the truck in.
You can also get the 6.2L L99 in the LTZ. It also has AFM and VCT. What I am wondering is how you would specify all the Max Trailering options with the 6.2. In other words can you order an LTZ with the Max Trailering package and get the 6.2L instead of the 6.0L?
My suspicion is the you just probably order the LTZ withthe 6.0L and order a heavy duty trailering package, but its not the VMax package. But i have not confirmed that.
Old Aug 28, 2009 | 09:17 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
2010, yes.
2009, I'm not sure if you could get that combo or not. Not that it matters, because GM stopped taking orders for 09's months ago. I guess you could do a dealer inventory search and see if one pops up.
All the 2010 info I have seen shows that GM has dropped the 6.0 from the 1500 lineup completely. The 6.2 is now standard on all Vmax's. 2010 production starts up mid-October.
Old Aug 29, 2009 | 11:57 PM
wrath's Avatar
2010, the L76 is toast. You either have the L9H 6.2L, LC9 5.3L, LMG 5.3L, L20 4.8L or LU3 4.3L.
You can get the L9H 6.2L on a LTZ/SLT Crew Cab as long as you get the 6L80e (MYC).
Otherwise, you can only get it with the NHT max trailering package. And it's only available on extended cab 6.5' box or crew cab 5.8' box. You can't piece your own together like you could in 2009.
Old Aug 30, 2009 | 12:00 AM
GMCtrk's Avatar
So it looks like the 6.0's days are numbered? Are the HD's going to the 6.2 as well?
Old Aug 30, 2009 | 09:46 PM
wrath's Avatar
6.0 is done in half ton trucks. The cast iron 6.0L is still around in 3/4 ton and up.
Old Aug 31, 2009 | 05:42 PM
graygmc's Avatar
This might be a dumb question but why didn't they drop the 4.8L and keep the 6.0L? Then make the 6.0L the "standard" engine. I also read that you will be able to get the 6.2L in a GMC SLE for 2010. I will be looking hard at buying one of those when they come out.
Old Aug 31, 2009 | 09:52 PM
wrath's Avatar
4.8L is the fuel miser of the bunch. The 6.0L/6 speed made sense since it got similar mileage as the 5.3L/4 speed. Now the 5.3L got the 6 speed also (in everything) rather than just crew cabs.
Looking at the sheets it appears with 2010 production that you can only get the 6.2L "build as you want it" in Denalis, crew/extended standard LTZs, crew/extended standard SLTs, and LT and SLE crew/extended standard with the NHT package.
Old Sep 16, 2009 | 12:43 AM
sand man's Avatar
why wouldnt they just put a 6.2 with the 6l80e on regular cab silvy/sierra i know for a fact that it would be a killer in every thing
Old Sep 16, 2009 | 07:17 AM
wrath's Avatar
Same reason they don't put an LS3 in a Solstice... fuel economy and practicality. We already know how well the SRT10 Ram sold...
Old Sep 16, 2009 | 08:11 AM
DBYRD's Avatar
if u ask me a WORK TRUCK would work better with more capability. and the 6.2 gets better gas mileage???
