Qa1 parallel mounted shocks
Old Jun 26, 2015 | 07:54 AM
121's Avatar
121
Default Shocks
Maybe on a fullsizi i guess. I run a soft *** monoleaf and can hook a drag radial in a car wash. Most light cars do best on a light spring and a good shock that can control the suspension. My suspension is set as loose as possible and the shocks control it. The suspension on my silverado was tight as **** and i spun 1.6860' times. Now days ecsb people make my ecsb times look junky. More than one way to skin a cat i guess...
Great info Definitely have my work cut out
Without the shocks, i can use 1 arm to bounce the rear end to the point that it bottoms out without using body weight.
I could pile 2 fat girls on the tailgate of the silverado to make it squat 1". It didnt hook for **** on slicks.
I forget that you were playing with a manual trans truck. I can see stiffer is better mentality in that application.
It's a th400 manual valve body with tbrake.
Definitely good info
Old Jun 26, 2015 | 08:06 AM
121's Avatar
121
QA1 Stocker Star Shocks TS403 - Free Shipping on Orders Over $99 at Summit Racing
Thanks George, This is what I have. Rule of thumb I was told is you want 60% for compression so that's where I have them at. But everything is adjustable if I need more or less.
Old Jun 26, 2015 | 08:18 AM
George C....'s Avatar
Formerly ScreamingL
Wow that's a short shock, ones I was looking at are around 21" extended
Old Jun 26, 2015 | 08:38 AM
121's Avatar
121
Yes they are. My truck is pretty low.
On a side note I wired my front left abs/ wheel speed sensor to the purple and green vss wires. Still no speedometer.
Old Jun 26, 2015 | 08:41 AM
121's Avatar
121
Old Jun 26, 2015 | 09:12 AM
Formerly ScreamingL
Did you adjust the revs per mile to match the and sensor?
There's a write up on ls1tech to do so
Old Jun 26, 2015 | 09:32 AM
121's Avatar
121
I did not. I will try and search on ls1. Just figured it would work but be way off. Definitely appreciate the help.
Old Jun 26, 2015 | 11:02 AM
TXsilverado's Avatar
damn. only about 4" travel. for street use, set them in the middle. for track use, you may try collapsing the shock some more to make sure you have 2.5-3" of extension travel on launch. it will never hook if it extends to the point that the shock bottoms out. my truck only has about 1.5" downward travel but it works for me since im much lighter than a full size.
Old Jun 26, 2015 | 11:20 AM
121's Avatar
121
I have adjustment with the bottom shock mounts I just setup everything in the middle so it gives me adjustment up or down. I'm gonna do testing after work
Old Jun 26, 2015 | 12:24 PM
sprayedenali's Avatar
there will be a lot of leverage on those upper mounts. you might want to look in to strengthening them some...
