Please help with choosing throttle body
Old Mar 15, 2012 | 11:03 PM
08Silveradojp's Avatar
Default Please help with choosing throttle body
I want a 102 from fast but the 08 trucks don't have cable drive to they aren't they just direct plug and play. I'll take pics tommorow to show what I have but I don't think it's. Cable drive and if it is how about installation.
Old Mar 15, 2012 | 11:40 PM
BrutalSierra's Avatar
Just get the ls3/ls7 tb off eBay or buy 11silvys if he still has his. It's a true 90mm should be plenty for ur app.
Old Mar 15, 2012 | 11:52 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I wouldn't bother with a throttle body if a ProCharger is in your future plans.
Old Mar 16, 2012 | 12:21 AM
It wouldn't help with intake manifold? I know it's not by much but I want to c how much power I can get from 4.8 before forced induction or n2o
Old Mar 16, 2012 | 12:32 AM
On a blow-through throttle body, 3mm larger throttle body won't make much difference at all. On a suck-through, it would be more worth-while.
So, if you plan on going turbo or ProCharger, I don't believe it's worthwhile. But, if you go Magnacharger, or N/A, or nitrous, then any increase in throttle body size helps. The bigger, the better.
Old Mar 16, 2012 | 08:36 AM
And another reason is it might be awhile
Old Mar 16, 2012 | 09:28 AM
You want a 102mm on a mild 4.8L? That's a total waste of money, not to mention that it won't bolt up to your stock manifold. I wouldn't bother with a 102, unless you had a 400+ci motor. Your stock TB is plenty for your N/A 4.8.
Old Mar 16, 2012 | 09:48 AM
It's not a 4 bolt and It wont bolt on the fast 102 intake if there not leaking I want one
Old Mar 16, 2012 | 11:22 AM
ak2007r6's Avatar
I remember you explaining it a little bit when I asked about the 90mm upgrade after I installed my PC but this really helps explain the differences and benefits and why depending on the FI how much of an impact it will make.
Thank you sir
natejk
Nov 15, 2016 08:05 AM
99bluefirebird
Sep 17, 2015 08:05 PM
jleews6
Sep 8, 2015 10:17 AM
bisqikss
Sep 8, 2015 03:35 AM
gmcyukon
Sep 7, 2015 08:46 PM
