Ordered Whipple
#43
IF whipples tune is based on a stock tune that is older than the stock tune in your truck, it may not load.
I had that problem with a Radix a few years back and had to send the handheld back to
Magnason for an update. The stock calibration was updated by the dealer and I could not reload the radix tune afterwards.
Could be a similar issue and Whipple may not be aware of that
#44
What kind of handheld is it?
I know you might have to pull some fuses foraftermarket devices and onstar.
Make sure you have no ipod connected. Basically u want you truck turned on to accessories with nothing running. Nothing non factory connected to the truck. I know alot of the companies send DS predators with their custom tune downloaded on it. If it is a DS try looking up their forum and ask Mikel or anyone else in the tech support. They should have you up and running in no time.
#45
Another update: I talked to Jeff at Whipple this morning. He said that superchips was working on the problem. Apparently, my truck contained a new file that superchips had not seen before. He said that it should be done by this afternoon. I know that Whipple has not had a great reputation for customer service, but I have to say that their customer service in my case has been fantastic. I have dealt with many aftermarket companies over the years and Whipple definitely ranks at or near the top from my personal experience. With luck, I might be able to report that I'm up and running by this evening.
#48
We need some tire burning videos.
Good luck.
#49
It's alive!! Got the update this afternoon and everything is running great! The system is really quiet! The extra power is very nice, like an executive jet taking off. I will be going to Norwalk in the next few weeks to get some 1/4 mile numbers. I will also post some pictures here. I am very pleased with the kit as a whole. All of the pieces are of a very high quality. There are some areas that they might want to address in their installation manual, but there are a surprisingly large amount of variations between GM truck models and engines, so much of it was model/engine specific.
For now, I'm going to keep an eye on things and make sure that nothing has worked loose. I also havent had much of an opportunity to fully dip into the power. I have HP Tuners software so I'm going to use the scanner to see how much boost it's making among other things.
Rich
Rich
#50
