Am i missing something for DOD/VVTdelete
Old 05-30-2017, 04:31 PM
Registered User
6.2lover's Avatar
Default Am i missing something for DOD/VVTdelete
Hello all im about to do a delete on my 2010 4x4 LC9 and want to see if im missing anything. Thanks
1) water gasket
2) exhaust gasket
3) head gasket
4) LS7 lifters
5) head bolts
6) crank pulley bolt
7) timing cover
8) timing chain
9) timing chain sprocket
10) cam bolt for sprocket
11) timing cover gasket and seal
12) oil pump o-ring
13) lifter trays
14) cam retainer bolts
15) camshaft
16) springs
17) pushrods for milled heads
18) Trunnions kit for rockers
19) intake gasket
20) non dod valley cover
21) tune
Old 05-30-2017, 07:15 PM
psycho1's Avatar
You might want to get exhaust manifold studs or new bolts just in-case the mani bolts don't want to come out.
Old 05-30-2017, 07:28 PM
Registered User
6.2lover's Avatar
Thanks i will add that to the list
Just trying to get everything i might need before tearing it apart
Old 05-30-2017, 10:02 PM
psycho1's Avatar
This is where I got my kit from when I did mine
https://www.briantooleyracing.com/bt...elete-kit.html
Old 05-30-2017, 10:31 PM
Registered User
6.2lover's Avatar
I was looking at TSP for most of the items i would need and Sumit for the rest. But im still looking around so thanks for the link.
Old 05-31-2017, 07:13 AM
madmann26's Avatar
A tune.
It is required when doing the DOD/VVT delete.
Old 05-31-2017, 09:39 AM
Registered User
6.2lover's Avatar
Originally Posted by madmann26
A tune.
Just added
Thanks
Old 05-31-2017, 02:15 PM
Registered User
6.2lover's Avatar
Ok think i have the list of 99.99% of parts ill need to do this job. I just sprayed WD40 on the exhaust bolts and one by one unbolted then bolted back. So we good there when it's time to do the delete. I hope this list can help others that's looking in doing this themselves. So for without head work and tune im right around $1300.00 of so.
1) 16 ls7 lifters
2) MLS head gaskets
3) head bolts
4) L92 valley cover
5) crankshaft bolt
6) LS2 lifter trays
7) timing cover gasket
8) front crankshaft seal
9) water pump gasket
10) LS2 chain dampener
11) LS3 timing cover
12) 3-bolt camshaft gear
13) camshaft bolts
14) camshaft
15) trunnions kit
16) valve springs
17) cam retainer bolts
18) LS2 timing chain
19) pushrods
20) intake gaskets
21) exhaust gaskets
22) o-ring for oil pump
23) tune
Old 06-02-2017, 05:33 PM
Quick question: why the o-ring for the oil pump? Are you putting in a new oil pump or leaving in the stock one. If your leaving it in you shouldn't need to loosen it.
Old 06-03-2017, 07:35 AM
Registered User
6.2lover's Avatar
I'm going to have just incase i have to take to oil pump off. I don't want to be in the process of putting everything back together and run into a problem.
