Am i missing something for DOD/VVTdelete
Hello all im about to do a delete on my 2010 4x4 LC9 and want to see if im missing anything. Thanks
1) water gasket 2) exhaust gasket 3) head gasket 4) LS7 lifters 5) head bolts 6) crank pulley bolt 7) timing cover 8) timing chain 9) timing chain sprocket 10) cam bolt for sprocket 11) timing cover gasket and seal 12) oil pump o-ring 13) lifter trays 14) cam retainer bolts 15) camshaft 16) springs 17) pushrods for milled heads 18) Trunnions kit for rockers 19) intake gasket 20) non dod valley cover 21) tune |
You might want to get exhaust manifold studs or new bolts just in-case the mani bolts don't want to come out.
Thanks i will add that to the list
Just trying to get everything i might need before tearing it apart |
This is where I got my kit from when I did mine
https://www.briantooleyracing.com/bt...elete-kit.html |
I was looking at TSP for most of the items i would need and Sumit for the rest. But im still looking around so thanks for the link.
A tune.
It is required when doing the DOD/VVT delete. |
Originally Posted by madmann26
(Post 5410404)
A tune.
It is required when doing the DOD/VVT delete. Thanks |
Ok think i have the list of 99.99% of parts ill need to do this job. I just sprayed WD40 on the exhaust bolts and one by one unbolted then bolted back. So we good there when it's time to do the delete. I hope this list can help others that's looking in doing this themselves. So for without head work and tune im right around $1300.00 of so.
1) 16 ls7 lifters 2) MLS head gaskets 3) head bolts 4) L92 valley cover 5) crankshaft bolt 6) LS2 lifter trays 7) timing cover gasket 8) front crankshaft seal 9) water pump gasket 10) LS2 chain dampener 11) LS3 timing cover 12) 3-bolt camshaft gear 13) camshaft bolts 14) camshaft 15) trunnions kit 16) valve springs 17) cam retainer bolts 18) LS2 timing chain 19) pushrods 20) intake gaskets 21) exhaust gaskets 22) o-ring for oil pump 23) tune |
Quick question: why the o-ring for the oil pump? Are you putting in a new oil pump or leaving in the stock one. If your leaving it in you shouldn't need to loosen it.
I'm going to have just incase i have to take to oil pump off. I don't want to be in the process of putting everything back together and run into a problem.
