Am i missing something for DOD/VVTdelete
Hello all im about to do a delete on my 2010 4x4 LC9 and want to see if im missing anything. Thanks
1) water gasket
2) exhaust gasket
3) head gasket
4) LS7 lifters
5) head bolts
6) crank pulley bolt
7) timing cover
8) timing chain
9) timing chain sprocket
10) cam bolt for sprocket
11) timing cover gasket and seal
12) oil pump o-ring
13) lifter trays
14) cam retainer bolts
15) camshaft
16) springs
17) pushrods for milled heads
18) Trunnions kit for rockers
19) intake gasket
20) non dod valley cover
21) tune
1) water gasket
2) exhaust gasket
3) head gasket
4) LS7 lifters
5) head bolts
7) timing cover
8) timing chain
12) oil pump o-ring
13) lifter trays
15) camshaft
16) springs
19) intake gasket
21) tune
Ok think i have the list of 99.99% of parts ill need to do this job. I just sprayed WD40 on the exhaust bolts and one by one unbolted then bolted back. So we good there when it's time to do the delete. I hope this list can help others that's looking in doing this themselves. So for without head work and tune im right around $1300.00 of so.
1) 16 ls7 lifters
2) MLS head gaskets
3) head bolts
4) L92 valley cover
5) crankshaft bolt
6) LS2 lifter trays
7) timing cover gasket
8) front crankshaft seal
9) water pump gasket
10) LS2 chain dampener
11) LS3 timing cover
12) 3-bolt camshaft gear
13) camshaft bolts
14) camshaft
15) trunnions kit
16) valve springs
17) cam retainer bolts
18) LS2 timing chain
19) pushrods
20) intake gaskets
21) exhaust gaskets
22) o-ring for oil pump
23) tune
1) 16 ls7 lifters
2) MLS head gaskets
3) head bolts
4) L92 valley cover
5) crankshaft bolt
6) LS2 lifter trays
13) camshaft bolts
14) camshaft
15) trunnions kit
16) valve springs
19) pushrods
20) intake gaskets
21) exhaust gaskets
23) tune
I'm going to have just incase i have to take to oil pump off. I don't want to be in the process of putting everything back together and run into a problem.
