NNBS Fog Light Harness!!!
Old Dec 31, 2012 | 12:38 PM
sand man's Avatar
you need to change all the front head light harness to get the fogs working , or you can wire it yourself and pin the harness to the fuse block end of the harness
[IMG][/IMG]
Old Dec 31, 2012 | 12:55 PM
sand man's Avatar
here is the harness , you can see the head light / fogs / windshield washer pump&level sensor / and E-fans are togther
Old Dec 31, 2012 | 02:36 PM
javzh's Avatar
sorry sand man they might be in the same wire cover but they have nothing to do which each other. you dont have to change the whole harness to get the fogs to work.
the harness has only two plugs for the fog lights themselves, a ground, and the connector that goes into the fuse block. THATS IT.
if you want to make your own you can but youd have to get the connectors for the fuse block and the plugs for the fog lights themselves. or fab it up somehow. if you get HIDs in the fogs you can just connect them to that instead of buying oem fog light plugs.
the switch the OP already has simply replaces the switch without the fog light button.
like i said wire up the fog lights together to the fuse block and run ground together from fog lights. thats all my harness was when i added the oem fog light kit.
fuse block picture location.
Old Dec 31, 2012 | 08:57 PM
fcompean's Avatar
Hey thanks too all for the help..i know u can buy a whole kit including painted caps, harness (just fog harness i believe) , fogs and switch for around 280 but im going HD so i was looking for just the harness.
Old Dec 31, 2012 | 09:59 PM
4X4 GMC's Avatar
Default Fogs
Check the GMC kit, I think it is cheaper because it does not include the end bumper caps
Old Jan 1, 2013 | 08:06 AM
sand man's Avatar
Iyeah I know , thats way I said
" or you can wire it yourself and pin the harness to the fuse block end of the harness"
thats if you want the oem plugs and all
Old Jan 1, 2013 | 01:42 PM
08cheyennesc's Avatar
I just connected them to the low beam lights,been like that since 08.
Old Jan 3, 2013 | 12:47 PM
fcompean's Avatar
I believe this is the part number on just the harness 25866139
Old Sep 9, 2013 | 07:36 PM
chris092183's Avatar
Is this the correct p/n for the harness?
What I have:
new interior fog switch
bumper caps
fog lights w/about 8" pigtails
I need the harness (purple wire) that goes into the connector in the fuse block, ground wires and leads to the fog pigtails.
I don't have the special crimping tool to crimp the terminals so I'm pretty limited to just buying the harness.
Most say the trucks are pre wired but I have not found the pigtails by the fogs. I know for a fact I am missing the purple wire.
THanks in advance.
ARC
57
Feb 21, 2022 10:54 AM
Bluchevypick
Aug 18, 2015 09:11 AM
markyrgv
Aug 16, 2015 11:50 PM
pupi305
Aug 13, 2015 03:48 PM
Ketis
Jul 23, 2015 12:37 PM
