NNBS 2-4 Drop
Old Jan 1, 2012 | 05:54 PM
InsaneDomestics's Avatar
Question NNBS 2-4 Drop
I've looked but I haven't seen very many Shackle/Hanger setups for these trucks, so what are you guys doing to drop the back 4"?
Old Jan 1, 2012 | 06:24 PM
Allgonoshow's Avatar
A 2 inch shackle and block removal will give you 3.
Past that you need springs or flip kit.
Old Jan 1, 2012 | 07:02 PM
BrutalSierra's Avatar
I've been looking into the same drop. Seems like a flip kit and bell tech struts is the way to go.
I'm prolly gonna try the shackles and remove my lift block to see if I like it.
Old Jan 1, 2012 | 08:28 PM
jessanator's Avatar
My truck still sits higher in the back after shackles and block removal...
Old Jan 1, 2012 | 09:23 PM
youngone2011's Avatar
Mcgaughys has a 2" drop leaf spring and 2" shackle to get to the desired 4" rear drop ...
Old Jan 1, 2012 | 10:17 PM
06 4.8's Avatar
I used shackle, remove lift block, and spring clamps, and netted 3.75 drop and actually a little Cali lean (btw my sig pic is only with the shackles hence still having rake not Cali lean)
Old Jan 3, 2012 | 12:26 PM
I just finished 2" drop shackles and removed lift block, now my truck sits 35.5" from ground to fender lip rear and 36" front. WTF! how did my truck go lower in the back?
Old Jan 3, 2012 | 12:41 PM
06 4.8's Avatar
Mine did the same and im lighter being ext cab
Old Jan 3, 2012 | 03:11 PM
Then i'm blaming you!
Old Jan 4, 2012 | 06:26 AM
Does it look lower in the rear?
are the lips the same front and rear stock?
Put the block back in.??
