Need some input on gear selection
Old Apr 18, 2012 | 08:39 PM
Beatdown Z's Avatar
Laid Back
4.56 or 4.88's. There's hardly a difference between the two. With 4.88's you will be spinning about 2500 rpm at 70 mph.
That's the same as my 4.8 truck with 31" tires and 4.56's. 4.56's are the best thing I ever did to that truck.
Old Apr 18, 2012 | 09:20 PM
InsaneDomestics's Avatar
Is this with the stock stall? Id be happy runnin 2k @ 70
Old Apr 18, 2012 | 09:25 PM
Beatdown Z's Avatar
Laid Back
The converter is locked on the highway, so it doesn't matter if it's an aftermarket or stock converter.
Old Apr 18, 2012 | 10:07 PM
So how would it effect city driving?
Old Apr 18, 2012 | 10:51 PM
rjwz28's Avatar
Man Motor club
If you want 2k at 70 you'll want 4.30 over the 4.56 or 4.88. I've got 33s with 3.73s and would prefer 4.30s, but they're not available for my differentials.
Old Apr 18, 2012 | 11:01 PM
What differential do you have? Also, I have the rearend with drum brakes, are they worth putting money into or should I consider something different?
Old Apr 18, 2012 | 11:37 PM
All of the 6.2s (except AWD Denalis) have 14 bolts. You have the 8.5" 10 Bolt. When beefed up the 8.5" can hold decent power, so I wouldn't be worried about upgrading if I were you.
Old Apr 18, 2012 | 11:39 PM
rjwz28's Avatar
Man Motor club
I have a 2011 4x4 with the 14-bolt rear; I can't remember if it was the front diff or the rear (or both) that the 4.30 is not available for. Your 10-bolt will be just fine unless you have really big plans.
Old Apr 19, 2012 | 12:09 AM
Im leanin toward the 4.30s, what do they normally cost and where is a good place to get a set?
Old Apr 19, 2012 | 12:18 AM
rjwz28's Avatar
Man Motor club
http://www.ronsmachiningservice.net/servlet/StoreFront
