need some help, and advise
Old Jul 18, 2008 | 08:46 AM
chevy32's Avatar
Default need some help, and advise
so i went to low inc to order my drop yesterday and i want to get a djm 3/5 kit, and use the stock shackels to make it a 3/6, and the kit runs about 750 with everything, they want 1200 installed, is this a good price and do you think i can do it my self?? another thing is i bought 8k hids and i need help installing them, i cant figure out how to tap into a 12v and how to make them be able to be turned on and off help thanks
Old Jul 18, 2008 | 05:35 PM
SIERRA323's Avatar
the drop kit is pretty easy to install, just takes time and the right tools.... it shouldnt take more than a day to do it all. but if you have the money, i dont think that price is too bad for them to do it for you. i think that jb1 installed hids on his truck, he may be able to help on that...
Old Jul 18, 2008 | 07:29 PM
j225's Avatar
where are you putting the hids?Or are they just going in as headlights,if so i think you just plug the ballast in to your factory harness and the bulbs to the ballast.
JB will chime in and correct me if I'm wrong
Old Jul 18, 2008 | 07:41 PM
MislMan's Avatar
I wouldn't try to install the drop kit (rear flip) without 2-3 friends around to help hold and lift things. The springs and such are heavy and the rear-end housing wants to droop if not held in place. Also, trucks take some pretty large size tools to work on the suspension bolts (larger than 1") not to mention you will have to remove 6 rivets that hold the hangers to the frame. For a complete install for a 3x5 DJM kit, I think $500 is a good price.
Later ... Larry S.
Old Jul 19, 2008 | 11:28 AM
tomtom818's Avatar
i'm not sre what HID kit yo bought, but mine on my 07 NNBS were simple plug and play. just plug from existing harness into ballast, then put the bulbs in. I didnt have to tap into any wiring. The hardest thing I had to do was figure out where to mount the ballast.
Old Jul 19, 2008 | 12:03 PM
GMade03's Avatar
im sure you and some buddys can get the drop kit done if you have tools available. if anyone you know has experience with a grinder/cuting wheel then your all set for the notch if not then i'd pay to have the notch done right and then do the rest on your own
shawn96gmc
May 17, 2016 04:15 PM
BIGD4504
Jul 28, 2015 11:46 AM
sauldgold
Jul 23, 2015 02:15 PM
mrspeed64
Feb 18, 2005 09:55 PM
