NBS 2007 Drops a Cylinder
Old Jun 1, 2007 | 11:45 PM
2006 8.1's Avatar
Default NBS 2007 Drops a Cylinder
At 6500 miles, the 1/2 ton gasser dropped a cylinder on the way home. I think it either broke a rocker shaft, or one of those special lifters failed and the valve is not opening. Anyway, it is missing badly and hammering pretty hard. I took it to the dealer, but have not heard back yet. This 5.3 is the all alum version. Don't know if that makes any difference. Will let you know the outcome.
The active fuel management is not working and the dash said that the stabilitrack was not working and traction control wasn't either. Weird.
Old Jun 1, 2007 | 11:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Sucks to hear that. Hopefully it's not something that will keep it down long.
Old Jun 2, 2007 | 09:37 AM
budhayes3's Avatar
PT's Slowest Truck
That sucks, hope it's something simple. Pretty sure that the reason that the stabilitrack and traction control stopped working is due to the misfire fault found in the pcm, which puts the vehicle in failsafe mode and either loses communication with or disables the traction and stability control functions. Once the problem is fixed and the trouble data cleared the other lights/failures will clear also.
Old Jun 4, 2007 | 10:31 PM
bigredexpress99's Avatar
Any updates on this?
Old Jun 4, 2007 | 11:48 PM
2006 8.1's Avatar
Well the truck has been at the dealer for 2 days and hasn't moved an inch. Went by there today, and noticed that they haven't even looked at it. One more day, and I will take it somewhere else. I told the guy that I earn my living with that truck (company truck). NOt sure he really cared all that much.
The more I think about it, I think it could be a failed lifter, that colapsed and is not letting the valve open. The Active Fuel Management is not working, so I wonder if that is because a lifter failed. Either that or broke a rocker shaft. I noticed the other day after it happened, I shut it off and I could hear the compression of the cylider bleeding off. It was seeping, leading me to believe that a valve was not opening as it Should. They promised they would have an answer for me tomorrow.
I will let you know.
Old Jun 5, 2007 | 08:10 PM
bigbadwolf54's Avatar
13 Second Truck Club
seen a few NNBS with broken valve springs........
Old Jun 5, 2007 | 08:18 PM
Spoolin's Avatar
GFYS and STFU
What does removing the screen out of the Mass airflow do?
Old Jun 5, 2007 | 08:57 PM
02_2500avalanche's Avatar
Absolutley nothing lol....i too once thought it did something a couple of years ago then i put the screne back it and it seemed like it got better throttle response
Old Jun 5, 2007 | 09:15 PM
Spoolin's Avatar
GFYS and STFU
I was wondering what his mods were in case the stealership wanted to claim something about the warranty being compromised.
Old Jun 5, 2007 | 11:04 PM
2006 8.1's Avatar
Well, the verdict is in, and it seems I was pretty close on this one. The number one cylinder had a lifter collapes and would not open the valve. They have to remove the head to get the lifter out, and the head bolts are what is going to hold this process up. It was one of the AFM lifters that failed. Not giving me a warm and fuzzy that is for sure.
They are going to replace the push rod and rocker as well.
I hope I don't have this issue on the rest of the special lifters. This will get old.
