nav radio problems
Old Mar 12, 2009 | 11:25 AM
86T-Top TA's Avatar
Default nav radio problems
trying to add factory navigation radio to truck without bose, sound is very low I know there have been posts on this before but cant find it. can someone tell me what i need to do. I have the factory harness from GM to add nav, installed the antenna and everything works fine but dont have much sound truck is a 2007 nnbs crew.
Old Mar 12, 2009 | 11:31 AM
nighthawk08's Avatar
has anyone successfully done this on a truck without bose?
Old Mar 12, 2009 | 06:46 PM
86T-Top TA's Avatar
any help would be great
Old Mar 13, 2009 | 12:10 AM
LawmanSS's Avatar
The factory navigation head units don't have internal amplifiers, that's why the sound level is low. I don't know if you can add the Bose amplifier and wiring harness to your audio system to make it work. I've read and been told by someone who works at a dealership that the GM Nav head units aren't anything close to "plug and play" on non-Bose trucks. You may be better off buying a "breakout box" such as the JL Audio Cleansweep which will enable you to use an aftermarket amplifier to drive your factory speakers.
Old Mar 16, 2009 | 12:47 PM
white lightning SS's Avatar
You will need to install an amp for sure. I even had to change amps from the regular Bose to get the nav radio to work. The nav radio uses a Class II communication amp. The regular Bose does not.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
