LY6 Swap
Old Jan 22, 2010 | 03:15 PM
CJ Hungus's Avatar
Default LY6 Swap
I am going to take a look at a LY6 out of a 2007 Chevy 2500 HD. From what I have read, this should be a direct swap, but I just want to make sure that it will be. Truck is in sig. Also what should I make sure to get while I am there, I think I read that I need to get the L92 fuel rails because they are different than the 5.3s.
Old Jan 23, 2010 | 12:26 AM
rgvsierra's Avatar
i did the swap on my 4 door, its not exactly bolt on.. you need to change a few things..
Old Jan 23, 2010 | 10:37 PM
iamkeniff's Avatar
ok..an what are the few things to change?
im looking to swap a 6.2 later on...any info is greatful
Old Jan 24, 2010 | 12:40 PM
CJ Hungus's Avatar
Yeah, what is all needed to sway a LY6 into my truck?
Old Jan 25, 2010 | 06:12 PM
rgvsierra's Avatar
ok, well your gonna have to use your stock cam,timing cover and sproket from 5.3, or swap to the gen 3 style cams, like i did. leaving the stock vvt cam and it will advance it since your truck has no harness connector to control the vvt.
your gonna have to tune out the dod in the pcm, if not possible right away you can swap valley covers, swapping out valley covers is to prevent the motor from going into a limp mode, due to the connector in back of cover not getting a signal. it will start to sputter/misfire setting several dod codes. but the 5.3 valley cover on the 6.0 will read lower oil pressure in cluster, not sure why.
while your at it, swap your 5.3 oil pump to the 6.0, its higher volume than the standard 6.0 pump. i did that on mine and it has good oil presure all the time.
those are the things i went through, and i see your truck is afm. a truck without afm/dod, wont have those problem, but will still have to swap cams out, unless a vendor is selling harness conversions to make the vvt work on trucks that didnt come with it from factory.
Old Jan 25, 2010 | 08:11 PM
MOT0410's Avatar
Default Ly6
Old Jan 26, 2010 | 04:48 AM
iamkeniff's Avatar
just upgrade to what single bolt cam you want an use your timing cover
Old Jan 26, 2010 | 12:21 PM
CJ Hungus's Avatar
Great info! thank you very much. One question about the cams, what if I tune out the VVT, then can I run the standard Gen IV cams with the single bolt? I guess I am asking why you changed to a Gen 3 cam? just to get rid of the VVT?
Edit: I just saw iamkeniff's reply and figured I could just use my timing cover and an aftermarket single bolt cam. alright thanks.
Old Jan 26, 2010 | 12:27 PM
DV2000NJ's Avatar
13 Second Truck Club
You'll never do it, Carl.
Old Jan 26, 2010 | 12:30 PM
CJ Hungus's Avatar
I'll cut you I just don't know if I want to find a lower mileage engine or not, and if I'm ready to start breaking stuff
