LSA Supercharger in 6.2L NNBS?
Old Nov 4, 2015 | 09:08 AM
ClintBeastwood's Avatar
Originally Posted by camcamaro1991
Yes, there are a few folks that have done this hence why I added the info above (I am not supercharged, but been eye balling systems). I think it would get more traction if posted in the Forced Induction forum.
Would I be better off buying a pre selected kit or trying to piece it together myself to save some money? There's a bracket kit on eBay for the trucks for $475 and you can get used blowers. But that still leaves all the odds and ends out. Without a list of all the part numbers it'd be really hard to get all the little things
Old Nov 4, 2015 | 01:05 PM
camcamaro1991's Avatar
Post
Depends, I love the fitment of the Edlebrock e-force supercharger for the GMT-900 setup along with keeping the factory airbox for factory style replacements (Edlebrock uses "Green filters" similar to K&N oil style filter and say since they are only $40 to just throw them away instead of cleaning them, they can be found on Amazon, the Edelbrock rep also confirmed a GM paper filter will work but will limit air flow and volume), it comes complete and they offer a 3 year 36,000 mile "product warranty" on the charger system (this is separate from the power-train warranty which they offer 2 version's) so buying a LSA takeoff will not, you are the warranty if something fails.
Edelbrock, claims their superchargers are quieter than other brands (my limited understanding, but this is b/c the 2300/2.3L can be spun slower/less to achieve the same pressure). It comes with TVS 2300 rotors, which are the same as the LS9 rotors. I confirmed they do sale smaller 6 rib pulleys for the e-force chargers so you not limited to Edelbrock stock 6 lbs of boost due to CARB emissions. Looks to be a easy swap process for pulley & belt change along with a new custom tune, Edelbrock only supports their respected software tunes within parameter's of supercharger type per vehicle, however you will be limited to max boost due to belt slip since a small 6 rib belt is being used. This has not stopped some other guys, some guys are running 10lbs of boost with these blowers using a 6 rib belt.
I am leaning more towards the Edelbrock system, only due to the fact that I can do it over the weekend bolt it on and done, then later get a custom tune, folks on here say the CAN tune leaves some things to be desired.
It comes down to cost and your time, I don't have as much time as when I was younger. the LSA can be done for much less, I guess between $2,500 - $4,000 depending on the used condition and getting all the parts, you notice on most the ebay listings they don't include the lid, bolts, etc... btw those bolts are high dollar.
Edelbrock LINK
Old Nov 5, 2015 | 07:44 AM
Jonblarc7's Avatar
Just a couple of the ebay links. I'm not positive which one a 6.2 guy would need.
1. LSA supercharger truck accessory relocation kit 8 groove kit use fbody water pump
http://www.ebay.com/itm/LSA-supercharger-truck-accessory-relocation-kit-8-groove-kit-use-fbody-water-pum/252157034941?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34225%26meid%3D8a95b4f0a30e4b6f938576be67d41f70%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D371480274248
2. LSA supercharger truck accessory relocation kit 6 groove kit use 07 up truck wp
LSA supercharger Truck Accessory Relocation Kit 6 Groove Kit Use 07 Up Truck WP | eBay
I think it would be number 2 for a 6 grove set up and number 1 for an 8 grove set up.
Old Nov 5, 2015 | 11:09 PM
Has anyone assembled a parts list for the swap? Providing you have the brackets and the base blower already. Base as in no lid no fuel rails etc.
If I could just walk into my chevy dealer with a list of part numbers id have a blower on my truck before christmas
Old Nov 6, 2015 | 04:59 PM
Pulled this from a G8 forum, some of these parts are not needed I guess we can edit this list as time goes on for GM trucks.
19257754 Supercharger with bypass
12622236 ZL1 Supercharger lid / 12631035 CTSV Lid
12612467 Lid Gasket/Insulator
12605222 Fuel Rail
12598646 LSA Injectors x 8
12639188 EVAP solenoid
11588718 SC bolts x 10
12639443 ZL1 Engine Cover / ??????? CTS-V Cover
11589406 Engine Cover Studs x 4
12603916 Crank Pulley
11570046 Crank Pulley Bolt
19180610 LS3 water pump 09 up
12606501 idler bracket
12606031 idler pulley
12606032 idler pulley
12606500 S/C tensioner bracket
12622452 S/C tensioner
11588749 Tensioner Bracket Bolts (x2)
11588742 Tensioner Bracket Bolt
12592525 3 Bar Map Sensor
12614717 IAT Sensor
25884797/226697069 Intercooler Filler Neck (This is a intercooler loop filler neck off a cobalt, you could do a tank or whatever, I just used this because it was small and easy to mount. NOTE: post on a cobalt forum looking for one, they take them off when they upgrade, way cheaper that way)
22697069 Intercooler Filler neck Cap
0392022002 Bosch Intercooler pump (This is the bosch part number)
20945282 GM Intercooler Pump (If you don't want to get the above off ebay for half the price..lol)
11588718 Intake Bolts (if you don't get them with your sc, you need ten)
LS9 Cam Here are the Part #s
12638427 Cam
12586481 Cam Gear
12556127 Cam Gear Bolts (x3)
LS3 water pump hose (upper): 92252958
(2) Idler pulley retaining bolts: 11518630
(1) Idler bracket bolt: 11900254
(1) Idler bracket bolt: 11588727
(1) Tensioner to bracket bolt: 11588752
Old Nov 12, 2015 | 08:55 PM
gunter96ws6's Avatar
This concept really needs to take off.
Old Nov 13, 2015 | 02:37 PM
Jonblarc7's Avatar
Its gaining traction.
It's not a NNBS but I'm going to leave this here for future searches!!! For a LSA swap
https://www.performancetrucks.net/fo...ite-up-540743/
Old Nov 15, 2015 | 07:56 PM
Medic/Z28's Avatar
I'm on board on this. I've been wanting to do this for a 1 yr now. Closest I got was a it might work from ebay seller. So I placed it on back burner
Old Nov 17, 2015 | 09:00 AM
2 SSlow's Avatar
I am doing this on my 2007 Escalade. Getting parts together now. I would really like it to be done in the next couple months. We'll see how everything goes
I am curious if my stock NON Flex Fuel pump would support 6-7psi though.
Old Nov 17, 2015 | 01:18 PM
Your going to need at "least" a flex fuel pump or better pump, to supply those LSA injectors.
