lifters+ Valve springs
Old Apr 25, 2009 | 10:20 PM
lucky77's Avatar
Banned
Default lifters+ Valve springs
HAs any-b done a Lifter Upgrate on the NNBS during there cam swap . . who has the part number for V-springs from comp cam.. that fit our NNBS . .?
Old Apr 25, 2009 | 11:36 PM
Noah Burns's Avatar
comp 918 are about as good a spring you can get... the comp 850 lifter is a good replacement, not sure if they will work in a VVT motor with VVT turned off though.
Old Apr 26, 2009 | 12:25 AM
silver-mod-o's Avatar
Hunt&Fisherator
steer clear of the 918's IMO... too many of them breaking and dropping valves lately. I run Crane duals.
Old Apr 26, 2009 | 11:41 AM
scooter k's Avatar
I put GMPP lifters in which are basicly LS7 lifters. They will work with VVT motors since the lifters have nothing to do with that. The GMPP lifters said they would work with several LS motors.
Old Apr 26, 2009 | 11:46 AM
POPO1984's Avatar
are those GMPP ls7 style lifters the same as the cts-v lifters
Old Apr 26, 2009 | 12:26 PM
Lama1's Avatar
RUN LS7 lifters, and LS6 springs, and the whole darn $600 worth of junk you need to pull the lifters. I PM'd you.
Ive been there already, it sucks to spend that much on a cam change, but that is the deal with the AFM/DOD bullcrap motor.
If you are cheap you can buy just 8 GM replacement lifters and re-use the 8 "good" (Same as LS7) lifters that are in the engine already. Be careful though, you need the LS3/ LS7 lifter trays.
It's not a fun job. The key is the LS3 type valley tray cover, to keep the oil from bleeding after the LS7 lifter install.
Old Apr 26, 2009 | 01:50 PM
Noah Burns's Avatar
basically you can run a "small" cam with the DOD motors without having to change the lifters right? I've heard anything around .550" lift is the max, not sure thats true or not. However, if the LS7 lifters will allow me to maintain AFM/DOD and run a larger cam without turning that feature off, that would be SWEET!!
Old Apr 26, 2009 | 09:33 PM
chakoman's Avatar
Default cam swap
I am putting in a vinci trucker cam in my truck this week and I will give a detailde report. I am also putting in new rocker arms (1.8 ratio), push rods, dual springs and lifters. I hope it all goes smooth, but you know how it is.
Old Apr 28, 2009 | 05:17 PM
Lama1's Avatar
You need:
*12574294
GASKET
*12612045
GASKET
*12557840
BOLT/SCRE
*12610311
GASKET
1 *12499225
LIFTER
*17800568
BOLT KIT
*12589226
GASKET
*12588670
LS2 TIMING CHAIN DAMPENER
*12617944
GASKET
*12595365
GUIDE
*12570471
COVER
BUY THE QUANTITIES LISTED NEXT TO THE ITEM NUMBER FROM GM PARTS DIRECT, THEY ARE THE CHEAPEST PLACE.
Plus you need:
1 Gallon pure ORANGE Dexcool Coolant and WATER
6 QTS. Mobil-1 OIL
1 PF-42 OIL FILTER
ANTI-SIEZE
2 CANS BRAKE KLEEN
TORQUE WRENCH
BLUE LOCTITE
GREY ENGINE RTV
LOTS OF RAGS AND PAPER TOWELS
SPECIAL TOOLS FOR CAM CHANGE
SPECIAL TOOL FOR TORQUE-TO-YIELD HEAD BOLTS
Disconnect your battery while doing the job,please. After the lifter/head install, it will run perfect, and your performance will be restored, and your cam will sound healthy!!!
The engine will be SUPER QUIET from a valvetrain point of view.
MARK THE INJECTOR WIRES TO THE CORRECT CYLINDER.
Clean the heads and the block with BRAKE KLEEN and a rag ONLY!!!! Do not scrape them!!!
DOUBLE CHECK YOUR WORK.
CHANGE THE OIL AFTER YOU HAVE DRIVEN FOR 1 DAY.
IF YOU NEED TO RENT THE TOOLS, I HAVE THEM ALL.
Old Sep 14, 2009 | 04:02 PM
iamkeniff's Avatar
i know its been a while since this thread has been replied to.
why do you need a 12599670(timing chain damper)
also you have all the seals and gaskets seperated, why not buy a cam kit(12499228)
if i want to keep my stock type cam(1bolt) or is it wiser to go with the 3 bolt sprocket? whats the part number for the 3 bolt sprocket that will work with my 08 5.3 timing cover?
