Lifted the truck and having ABS problems
Old Mar 24, 2009 | 04:45 PM
Default Lifted the truck and having ABS problems
I was just curious if any of you guys with lifted trucks are having this problem. It seems everytime i make a U-turn or coming off my driveway and turn the ABS light turns on. Any ideas here guys?
Old Mar 24, 2009 | 06:21 PM
Lama1's Avatar
Check your wheel speed sensor wiring, sounds like you are pulling (stretching) the harness as you extend the suspension.
Old Mar 24, 2009 | 06:25 PM
ChevyTruck's Avatar
something else
That is the first time that I have ever heard about that problem... check if there is anywhere where the wire is zip tied up some where.
Old Mar 25, 2009 | 01:13 AM
Wonderer876's Avatar
I never had an issue except after my initial tune, retune prob solved
Old Mar 25, 2009 | 01:57 PM
Thanks guys. My buddy has HP Tuners so maybe he can track which sensor it is.
Old Mar 26, 2009 | 11:33 AM
SS94S10's Avatar
I have had the issue if you put a tuner in a truck the abs light will come on if you tune for 35" or larger tires. Calibrate for a 34.75" no problems. Not sure if that helps.
Old Mar 26, 2009 | 01:04 PM
Yeah i havent tuned the truck or anything for the tires but thanks for the heads up.
Old Mar 31, 2009 | 04:47 PM
tallChevy's Avatar
did you change the gears with the lift
Old Apr 1, 2009 | 01:36 PM
Nope still stock gears.
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
1320Chicken
Jul 14, 2015 10:58 PM
