I Need Suggestions for Sway Bars
#41
#43
#46
no but the only difference is max has 3.73 gears. same rear end and hitch i have a 6.2l with a 9.5 14 bolt. the 5.3l have a smaller rear axle. Im dropped 3" that mite be why?
#47
Its hard to tell from the picture, but is that as close to the bottom of the axle tubes as you can mount the bar without it contacting the diff housing? It's really intended to be mounted dead center and if you have to mount them back at an angle like that, it may me causing the interference with your spare.
#50
Are you guys doing the front and rear or just rear? Where are yall getting them from? Also does the front bar come with new end links?
