I have a dumb lowering question
Thank you for the reply! The truck is a 2002 Chevy Silverado 1500 regular cab short bed. I’m trying to get it to a nice height without having to spend a lot of money because I’m not too wealthy. I’d be happy with a 2/4 drop if it means I don’t have to notch or use helper bags but I’m really looking for a 4/6 drop.
The notch is necessary for a 4/6 drop. Cutting the notch was much easier than I thought. Bought a pack of sawzall blades expecting to break a couple but did both sides with only one blade (cut like butter). The hardest part was drilling all the holes... not hard but time consuming. Most that do a 2/4 wish they'd went with the 4/6 kit.
Let’s say I do cut a notch out in my frame for a 4/6 drop and install the kit and everything, if I were to set my suspension back to normal for any reason and flip the axle back under the leaf springs, would the integrity of my frame be messed up and cause any breaks?
Not if you do a proper c notch, fully welded and boxed not open c channel. I’ve seen several c channel kits that are bolted in. When you Notch the frame you are now making the frame more susceptible to failing at the new notch. What I’ve seen happen is the bottom of the notch where the frame was cut begins to approximate or pinch together, buckling at the apex of the notch. Milnd you these trucks were also hauling trailers though too. I replaced the notch with a fully plated welding it in and no issues, it’s cheap insurance to fully box and weld it in. I’m sure others have opinions and more experience than me who can help you out too.
The underbed notch is essentially a "boxed" notch, but it fits under the bed so you wont have to cut it.
The picture posted above is a big notch, and would require to cut the bed.
this is the Reklez notch.
They sell specifically for 99-06 trucks, and its as easy as it can get, they even have a video on youtube for install.
https://reklez.com/collections/under...nder-bed-notch
Good luck
I know I'm digging way back in the files for this thread but thanks for humoring me on this...
Ive got an 05 Sierra CrewCab that I've put a 5/6 kit on with mini notch. The mini notch is the bolt in type but my real conplaint about it is that it still isnt enough clearance. I bottom out all the time against my axle. Since Im so close to being layed out already, im thinking about going ahead and doing the underbed notch to begin the process of bagging it. Would a underbed notch be enough clearance to lay frame with a wheel/tire diameter of 29-ish inches?
Thanks in advance for any help!
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
