How to wire in boost gauge?
Old 01-30-2015, 02:45 PM
High on diesel fumes
thunder550's Avatar
What year truck? There's a dimmer wire that comes off of the back of the headlight switch that's perfect for hooking gauges to. IIRC it's dark green on 99-02 and brown (maybe with black tracer?) on 03-06.
*nevermind, just saw this is in the GMT900 forum, this doesn't apply
Old 01-30-2015, 03:48 PM
TAPyvehc93's Avatar
So anyone know what wire to tap into on the dimmer switch panel? i am kind of working on it now and i am stumped.
Old 01-31-2015, 01:20 PM
TAPyvehc93's Avatar
BUMP. Still looking for which wire to tap into. My voltage meter will not fit into the prongs so i can't test it.
Old 02-03-2015, 01:40 PM
wanablaze's Avatar
Unfold a paperclip and slip it between the contacts. Then you can use your voltmeter.
Old 02-03-2015, 08:10 PM
Choda's Avatar
I went to the fuse in the box under the hood. Push the wire in the slot w the fuse and it works w the lights
Old 02-04-2015, 06:18 AM
I have a gauge for that
Atomic's Avatar
An add-a-circuit is the best way to do that ^
Old 02-04-2015, 07:00 AM
TAPyvehc93's Avatar
I have one of those! I wanted to avoid going under the hood though. I want my boost gauge to light up when the interior lights come on when its dark out. Unfortunately my boost gauge decided to stop working so i had to send it back to Summit. Im SOL for now.
Old 02-04-2015, 07:04 AM
Atomic's Avatar
Use the fuse for the cluster in the interior fuse box on the dash beside the drivers door.
chopperloco
07-10-2016 10:45 PM
thunder550
10-08-2015 04:53 PM
05GMC4.8
08-07-2015 09:55 PM
Ls3silverado
07-31-2015 04:22 PM
Quick Reply: How to wire in boost gauge?
