Higher stall with stock 6.2
Has anyone swapped their stock converter for a higher stall unit? I have a 2013 with a 6.2 and was curious if a higher stall would knock any time off my 0-60. I am getting ready to add an airaid mit and get a tune. Also, does the tune need done after a converter swap?
You should talk about your needs and goals with chris at circle d specialties.
I daily a 3000 stall and it was one of my first mods other then a tune. And yes you'll need a tune after thw swap
what are your plans leave it stock or cam and heads later on. if your leaving it stock probably 2600for 2800 triple disc circle D, Yank, or PI are all good. your going to like it
I have a great converter if interested for sale.
https://www.performancetrucks.net/fo...3400-a-520672/
Thanks for the input guys. My plans for the truck are headers, tune, airaid mit and converter. Later on it may see a 100 shot. My biggest concern is when it's got a trailer hooked to it and if i'm going to get it too hot towing. The truck seems like a converter would wake it up a little.
