fuel pump & low boost
Can my non-flex fuel pump support 450 whp? thats my power goals with my new setup and i was curious. Ive tried searching but im getting mixed reviews. new setup will be a 67mm turbo on low boost. and by low i mean 6-8 psi.
You will need some good sized injectors. Your fuel pressure will go down with increased flow and so your delta pressure will take a dive as well. FWIW, I haven't got a clue how much power I'm making, but my truck is flex fuel, I'm running 60# injectors, making a maximum of 8psi, my injector duty cycles hit 95-100% and my delta pressure goes down to about 36psi.
This is EXACTLY the route I'm taking. Talked to Julio at Alky Control this morning. Ive got a 2 gallon Trick reservoir and I'm going to send it to him to modify for his system. It will be set up to activate through MAF frequency so it can be a true daily driver meth system.
Monitor your current WOT fuel pressure at the rail and then report back.
90%+ IDC results in too little leeway for any legitimate tuner to optimize the combination, and increases the likelihood of melted pistons.
