fuel pump & low boost
Can my non-flex fuel pump support 450 whp? thats my power goals with my new setup and i was curious. Ive tried searching but im getting mixed reviews. new setup will be a 67mm turbo on low boost. and by low i mean 6-8 psi.
What year truck
2008 5.3. non flex fuel.
So in 5 years nobody has tried to push a stock pump?
I've run it to 600rwhp or so.
Originally Posted by smokeshow
(Post 4982334)
You will need some good sized injectors. Your fuel pressure will go down with increased flow and so your delta pressure will take a dive as well. FWIW, I haven't got a clue how much power I'm making, but my truck is flex fuel, I'm running 60# injectors, making a maximum of 8psi, my injector duty cycles hit 95-100% and my delta pressure goes down to about 36psi.
I ran a non flex fuel pump to 10psi on a TVS2300. The fuel pressure did start to drop at that boost level though. I ended up spraying meth as a suppliment.
Originally Posted by scooter k
(Post 4982500)
Monitor your current WOT fuel pressure at the rail and then report back.
90%+ IDC results in too little leeway for any legitimate tuner to optimize the combination, and increases the likelihood of melted pistons. |
