Front bumper replacement
Guy's had a ding in my front bumper forever and its been driving me crazy so it's time to change it,just wondering what kind of pain it is herd the bumper ends and crap have to come off just looking for a little info from people who have done it before.THANKS!
If its 2007.5+ there are 2 21mm bolts in the center and 2 15 mm bolts on the outside corners of the bumper one on each side ... If you pop the hood and take the plastic cover off to expose the bolts to the grille take the 4 10 mm bolts out on top of the grille then there are 6 metal clips on the grille you have to squeeze with some pliers to release and that comes off and the 2 21 mm bolts are easy to get to on the bumper. Or you can use a long extension but the bumper is easier to remove with the grille off if you are doing it yourself. There should be about 4 plastic push in clips holding a rubber piece to the bumper in the center of the actual metal part of the bumper also once u get the bumper off turn it upside down and it's pretty much straight forward on how to take it appart. You could take the bumper off take it appart and reassemble in under an hour.
Offroadunleashed
Jul 20, 2015 02:25 PM
