finally cammed...thoughts and questions
Old Apr 22, 2010 | 10:32 PM
jg53's Avatar
im assuming it was a dyno tune since you posted the rwhp and the cost. am i right?
Old Apr 22, 2010 | 10:33 PM
00ChevyScott's Avatar
Wearin' da big hat
Wow that better have been a dyno tune. Thats more than double what I paid for my own tuning software.
Old Apr 23, 2010 | 07:22 AM
silverad08's Avatar
Yes, it was a dyno tune and T/M was removed. also tuned for 93. Any muffler suggestions?
Old Apr 23, 2010 | 08:23 AM
Preston129's Avatar
This is unrelated to your posts, but out of curiosity did you happen to measure lifter preload? you went with 7.425 PRs and LS7 lifters correct?
Old Apr 23, 2010 | 08:36 AM
sonoma43's Avatar
For a muffler, I think the aerchamber would fit what your looking for, I run one with LT's and no cats with single tail pipe and it sounds good, it is a little quiet for me but loud enough for most people. I also have the TR220-112 cam in mine with a 3200 stall and it seems to do decent off the line considering the weight of it. I would look into your tune more, for a little more HP
Old Apr 23, 2010 | 09:19 AM
8.1 HD's Avatar
Definetly sounds like there is way more left in your tune, combined with the 3.42 gears. I'd go with 4.10's to get that thing out of the hole better.
Old Apr 23, 2010 | 10:51 AM
iamkeniff's Avatar
honestly i dont think your tune is up to the scale. even though your on 3:42s you should have had more HP than that. i would have guess 325-335.
how do you figure its a turd out the hole? if i flat foot my truck itll spin its *** off an i dont have any internal engine work an i have 3:42s
Old Apr 23, 2010 | 11:16 AM
bad intentions's Avatar
oh a dyno tune is different than street tunes, and i would also think that with a stall the tires would be done by now....like most of them are saying there is still HP that needs to be found i would take the tuner for a ride so he can feel his work.... and cant go wrong with magnaflow 3in muffler i really like mine.
Old Apr 23, 2010 | 11:39 AM
skipperdaddy's Avatar
TRUCKSHOP!!! WHERE ARE YOU!!!! Help this man out!!!!!
Old Apr 23, 2010 | 11:43 AM
silverad08's Avatar
cam, springs and pr's(7.425") came as a package from comp. used ls7 lifters and no I didn't check preload.
Just talked with the tuner and he said to bring it by tomorrow to check the surging issue...if its not pouring rain
Also he set my shift point at 6200 but won't that cam make power up to 6800 or so? I really dont want to tear up my stock tranny and if another 600rpm is where the extra 10-15hp is hiding, I'd rather just leave it alone. Just seems like I'm missing something down low. Once I hit about 35-40 the truck starts to feel strong, but seems weak up to that point. I realize gears would help but until I get a 4 banger to drive back and forth to work, I'll have to keep the 3.42s.
Does that magnaflow have much rasp or popping when you let off?
