Dynatech header kit.
Old Aug 11, 2010 | 09:20 PM
bschmity69's Avatar
Default Dynatech header kit.
Has anyone ran dynatechs kit with the lt headers, high flow cats, and y pipe on a 5.3? id like to hook it up to my corsa catback but would like some feedback first. thanks
Old Aug 12, 2010 | 05:33 AM
Allgonoshow's Avatar
they will bolt right up if your corsa bolts to the factory y-pipe
Old Aug 12, 2010 | 07:56 AM
icetraxx01's Avatar
I have that exact setup. I had to add a 3" extention between the y and the muffler because I had to pull the catback toward the truck. I just didn't like the fact that the corsa catback wasn't hanging straight up and down. I didn't have any issues running it either way. I will say that it is a tight fit for the dynatech y to go over the transmission brace. I think I have 1/16 to 1/8 clearance.
Old Aug 12, 2010 | 10:04 AM
Vegas Panton's Avatar
Default Dynatech Kit
Did the Dynatech system result in some good performance increases?
Old Aug 12, 2010 | 07:55 PM
first pic dynatech, had to notch my xmember to get them to fit, that was on an 07, fitment may have improved since.
2nd 2 pics, Arh headers, better shape and no fit issues.
Old Aug 14, 2010 | 05:09 PM
mikeith's Avatar
Anyone running kooks headers? I'm thinking about them in the 1 7/8" config. For the 6.2. But I haven't seen any reviews on here about them?
Old Aug 15, 2010 | 09:49 AM
Kooks still don't make a kit yet, if you are 2wd the camaro ones will fit with a custom y-pipe.
ARH has 1 7/8 [2nd pic above] with or with out cats
Old Aug 15, 2010 | 12:02 PM
jg53's Avatar
i noticed real good gains in the above 3500. easy install, but the fitment between the trans cross member and the y pipe, is a tight fit. it helped me to put wood chips in between the member and the y then tighten everything up. took the wood chips out and i have about a 1/4 inch of space in there now.
Old Aug 15, 2010 | 10:42 PM
mikeith's Avatar
you sure? i was at sdpc a few weeks ago and had them listed in their catalog both in 1-3/4 and 1-7/8 sizes. retail was right there with dynatech but i have a hookup there and they were going to run like 900 iirc with the catted y-pipe(assuming that they were listing something that was actually available). what did the ARH's run you
Old Aug 16, 2010 | 05:56 AM
you could be right, Kooks don't list them on their own website though.
ARH'S are more than $900, $900 would be a good reason to buy if they are
available.
