drive shaft question
Old Jun 16, 2016 | 08:18 PM
05GMC4.8's Avatar
Question drive shaft question
would a drive shaft from an extended cab short bed truck 2wd fit a crew cab truck with the super short bed 2wd?
my stock drive shaft finally blew out and i need to find another shaft asap so i plan on going to a u pull it or looking at local used auto part places tomorrow
I believe the wheel base is 143.5" for both crew and extended cabs, is that right? i also know that if its from a newer truck it will need to be a 4.8 truck to be sure it has the 4l60.
my truck is a 2008 crew cab 2wd
Old Jun 16, 2016 | 08:22 PM
Wolftrk99's Avatar
They are the same wheel base, so in theory the ds should work....
Old Jun 16, 2016 | 09:15 PM
FFDP's Avatar
2007-2009 Extended cabs even with the 5.3 will have a 4L60e.
I believe only the top on the line crew cabs in 2009 got the first 6L80e's in them.
Old Jun 16, 2016 | 09:25 PM
Wolftrk99's Avatar
Also keep in mind the engine is further back in an nnbs vs an nbs, best thing to do would be to measure it and get one same length....
Old Jun 16, 2016 | 09:42 PM
05GMC4.8's Avatar
10-4, thanks for the replies. ill be sure to look at nnbs trucks only
Old Jun 17, 2016 | 11:06 AM
05GMC4.8's Avatar
does anyone know the measurements on the driveshaft? i cant seem to find that info. on thread said 84 and change but then mentioned a 6l80e so i dont think that will work for me. one of the places i called said they need measurements or a part number to be sure
Old Jun 17, 2016 | 11:13 AM
Wolftrk99's Avatar
Anyway you can measure yours??
Old Jun 17, 2016 | 11:56 AM
05GMC4.8's Avatar
negative, it broke in half and im missing the back half that had the tag from the factory
Old Jun 17, 2016 | 12:08 PM
Wolftrk99's Avatar
That sucks..... It ext cab 2wd correct??
Old Jun 17, 2016 | 12:58 PM
05GMC4.8's Avatar
crew cab 2wd
