DOD delete without timing tensioner change?
Old Jan 11, 2015 | 08:01 PM
Vortec350ss's Avatar
I did. It was an L96 with ~90k on it. It was not in the car though and I didtched VVT in preparation for going into my saab 97x. The tensioner was fine... but since I did a cam swap outside of the vehicle I changed to the LS2 style.
Old Jan 11, 2015 | 08:02 PM
George C....'s Avatar
Formerly ScreamingL
Originally Posted by vettelovralexand
Anyone pulled a gen iv apart that wasnt broken?
yes what do you need to know? i tore down our TT-Notch motor and reassembled it
Old Jan 11, 2015 | 08:12 PM
vettelovralexand's Avatar
Just trying to gauge probability that ill have to change it out. Based on reading the G8/Camaro forums you would think there was a 100% failure rate with the timing tensioners. Obviously we have a couple examples here where that isnt true.
Old Jan 11, 2015 | 08:15 PM
Formerly ScreamingL
leave it alone can call it a day...no need to look into someone more then it needs to be
Old Jan 11, 2015 | 09:04 PM
shupe's Avatar
Mine want broken
Old Jan 12, 2015 | 12:40 AM
RS/SS 4.8's Avatar
10 Second Truck Club
When i did my cam @65k mi the tensioner was still lookin good. Now at 114k i think its still doing fine lol. When it gets warmer ill find out as i have to replace the front crank seal anyways.
Old Jan 12, 2015 | 10:09 AM
iamkeniff's Avatar
It's a problem with the Gen4 motors, its a simple swap, ease of mind that it wont cause issues later. So basically you are trying to save 23.00 for the tensioner, 10.00 for the o-ring and 30 minute job? That makes no sense.
Old Jan 12, 2015 | 10:56 AM
Not trying to save any money. I am trying to determine if there is more risk to leaving the tensioner or in trying to R&R the oil pump. Most people seem to think the single bolt cam needs a tensioner rather than the damper, and, if you do happen to mess up the R&R with either the O-ring issue or with shaft centering, you will be wasting a lot more than 30 minutes to tear the engine apart again and get it right. It also seems like it is more than 30 minutes on a 4wd anyway to get the pan lowered enough.
Old Jan 12, 2015 | 11:03 AM
Formerly ScreamingL
Its not a simple job on a 4wd
Old Jan 12, 2015 | 01:34 PM
kazfan30's Avatar
Good question!! Ive been thinking the same thing.. i dread dealing with the oil pump and i thought if i opened mine up and the tensioner wasnt broke then i would just leave that bitch alone lol..
