DOD/AFM Delete
Old Jan 20, 2016 | 07:01 AM
!Hostile!'s Avatar
Default DOD/AFM Delete
Sorry for the newbie post. Im sure it has been killed on here numerous times. Im about 3/4 of the way thru a head cam swap with the obvious delete. My questions are:
1: where does that PCV hose go? ITs u shaped about 5 inchs long. I got the delete kit that has the ls3 valley cover i see it has a hose pickup on it where the DOD one did not. It might be a CPT Obviouse once I put everything together but Im not there yet.
2: Got the ECM tuned to run Off road long tubes with no cats so it doesnt throw any codes. What do I do about the old O2 sensor wires? Tape them up.
Thanks sorry Newbie here
Old Jan 20, 2016 | 08:36 AM
Choda's Avatar
1. dont know
2. Yes, wire tie them up outta the way.
Old Jan 20, 2016 | 08:45 AM
!Hostile!'s Avatar
Do you know what that 5 or 6 pin plugin is on the very back of the harness its right next to the valley cover plug in. Right behind intake? Figured Id ask. it is blue.
Old Jan 20, 2016 | 03:45 PM
!Hostile!'s Avatar
1. you route hose to car intake on trucks you have to mod it so just plug it.
the one above^^^ its the plug for the AFM to work same as 02 sensors just wire tie out of the way.
Old Jan 20, 2016 | 08:11 PM
Wolftrk99's Avatar
All the afm connectors ive seen havebeen black, do youhave a pic of it
Old Jan 21, 2016 | 07:44 AM
!Hostile!'s Avatar
Correct it is black I missed quoted. It has the blue seal on it for a snug fit.
So a little on the build. I got here running last night.
TSP 220 581 cam. PRC 2.5's long tubes. Performabuilt trans Circle D 2800.
So I started her up. Shes on Jacks. Started just fine I noticed she was running rich filled my shop up with fumes. Started to top off fluids and the get tranny set. Once I put it in gear she would not idle. Had to keep burping the gas. It has a TSP mail tune. Im thinking its to rich at Idle. It threw a code and will know more tonight due to me not having my reader at the house. Any thoughts. I see this is pretty common but dont see where any one wrote a fix. Just needing a re-tune.
Old Jan 21, 2016 | 08:48 AM
Wolftrk99's Avatar
Need tohave it retuned mail order tunes are typically on safe side.... Headers may be affecting fuel trims
Old Jan 21, 2016 | 09:19 AM
!Hostile!'s Avatar
Im getting P0030 and 0050 heater circut for O2's but had TSP tune to remove them. starts fine just has low idle speed and wont idle and smells of being to rich and tubes were hot. acts like a vacuum leak. verified all connections.
2000_SS
Jan 13, 2016 09:12 PM
brjeep
Jan 8, 2016 11:50 PM
600 horses
Dec 16, 2015 05:18 PM
tim wellington
Dec 11, 2015 09:30 AM
MileHighSierra
11
Nov 24, 2015 06:17 PM
