DJM 5" rear drop bad problem HELP!!!
Old Jul 10, 2010 | 05:01 PM
iamkeniff's Avatar
damn, this problem really makes me not want to drop my truck anymore....SOB i hate problems like this.
Old Jul 10, 2010 | 07:04 PM
mikeith's Avatar
Originally Posted by iamkeniff
your yoke goes into the tranny, that should be 0* when you drop down to the (driveshaft) it should be -2* you're right. then when you get to the rear end that should be 0* at the rear end yoke. then when you put it back on the rear end you should see +2* on the driveshaft.
So what you are saying is that the front and rear yokes basically just need to be pedrectly parrallel giving them a 0* difference? And that the driveshaft should be (in simplified terms) angle upward from the rear yoke to the front one by 2*... Correct?
Old Jul 10, 2010 | 07:24 PM
iamkeniff's Avatar
basically, check that web site out on the last post on the 1st page. it breaks it down kinda well, it kinda says 1.5* difference or who knows ya know. id feel better with 2* bc you can see 2* vs guessing a 1.5*
Old Jul 10, 2010 | 07:28 PM
mikeith's Avatar
ok i just whipped this up in paint real quick....
does this look right?
Old Jul 10, 2010 | 07:32 PM
LaTampSStyle''s Avatar
all you need to do is kix your pinion angle.fix it and get somebody to tac the lower saddles from the bottom so it won't more anymore.i have a buddy that is an expert at dropping trucks he can answer any question you have one way you could get a hold of him is if you want to try myspace search for "drops r us" his shop is in pasadena tx you might have heard of it
Old Jul 10, 2010 | 08:53 PM
iamkeniff's Avatar
no, the tailshaft yoke is suppose to be 0* the ujoint on the drive shaft should be +2* then at the ujoint by the rear end its going to be -2* they cancel each other out basically.
Old Jul 11, 2010 | 09:43 AM
mikeith's Avatar
K find me a pic lol
Old Jul 11, 2010 | 10:44 AM
AKAFRED's Avatar
can you just move the axle back a half inch on the spring? you may have to drill another hole in the perch but it may be the easy solution.
Old Jul 11, 2010 | 01:06 PM
iamkeniff's Avatar
http://www.vibratesoftware.com/html_...tm#Information
Old Jul 11, 2010 | 05:19 PM
mikeith's Avatar
ok so i think i have it here's some pics. you guys let me know if i need to tilt the rear up or down and how many degrees i need to adjust if so. oh and btw after i went back and loosened and retightend i got the slack back unbinding the driveshaft putting it back into spec... the 3rd pic shows this.
(between -5/6* from tranny tailshaft)
(between +5/6* from rear pinion)
(about 3/4" play in driveshaft unfastened)
(driveshaft angle)
