DJM 5" rear drop bad problem HELP!!!
your yoke goes into the tranny, that should be 0* when you drop down to the (driveshaft) it should be -2* you're right. then when you get to the rear end that should be 0* at the rear end yoke. then when you put it back on the rear end you should see +2* on the driveshaft.
basically, check that web site out on the last post on the 1st page. it breaks it down kinda well, it kinda says 1.5* difference or who knows ya know. id feel better with 2* bc you can see 2* vs guessing a 1.5*
all you need to do is kix your pinion angle.fix it and get somebody to tac the lower saddles from the bottom so it won't more anymore.i have a buddy that is an expert at dropping trucks he can answer any question you have one way you could get a hold of him is if you want to try myspace search for "drops r us" his shop is in pasadena tx you might have heard of it
ok so i think i have it here's some pics. you guys let me know if i need to tilt the rear up or down and how many degrees i need to adjust if so. oh and btw after i went back and loosened and retightend i got the slack back unbinding the driveshaft putting it back into spec... the 3rd pic shows this.
(between -5/6* from tranny tailshaft)
(between +5/6* from rear pinion)
(about 3/4" play in driveshaft unfastened)
(driveshaft angle)
(driveshaft angle)
