Cooling question?
#21
They swapped to 34" in 05+ with efans.
Tune your truck to have the efans come on sooner. It'll help keep it cooler. Also a tru-cool 40k is around 145-150.00
There is a list of fittings and such for an fittings. Only issue with the 6L80e uses a "block" style transmission line to the transmission. You can spend the 70-80 on the block that uses AN fittings or use AN fittings to tubing fittings and cut your tubing up by the radiator or however you want to do it.
#24
Most tuners recommend to not tow if you have a tune....
Some of the gains made while tuning are done by leaning out AFR. It will make your engine run hotter. Just something to think about.
#27
I would be getting freaked out if the tranny went over 200. I have gotten into the low 180's a couple times after back to back to back pulls at the strip and that was really beating on it.
#29
i tow with mine....
Me too.
