Cooling question?
Old Jun 6, 2012 | 08:39 AM
  #21
iamkeniff's Avatar
They swapped to 34" in 05+ with efans.
Tune your truck to have the efans come on sooner. It'll help keep it cooler. Also a tru-cool 40k is around 145-150.00
There is a list of fittings and such for an fittings. Only issue with the 6L80e uses a "block" style transmission line to the transmission. You can spend the 70-80 on the block that uses AN fittings or use AN fittings to tubing fittings and cut your tubing up by the radiator or however you want to do it.
Old Jun 6, 2012 | 09:46 AM
  #22
Wide Open's Avatar
Is there just one or still two radiator options for the 05+ trucks?
Old Jun 6, 2012 | 10:08 AM
  #23
iamkeniff's Avatar
1 that i know of.
Old Jun 6, 2012 | 11:53 AM
  #24
Coban's Avatar
Most tuners recommend to not tow if you have a tune....
Some of the gains made while tuning are done by leaning out AFR. It will make your engine run hotter. Just something to think about.
Old Jun 6, 2012 | 12:49 PM
  #25
iamkeniff's Avatar
i tow with mine....
Old Jun 6, 2012 | 01:10 PM
  #26
NKPPhil's Avatar
Me too.
Old Jun 6, 2012 | 01:26 PM
  #27
ak2007r6's Avatar
Originally Posted by 2007chevy5.3l
Man if your just going off that little temp gauge on your dash then its wrong. My temp gauge always shows 210° all the time but when logging on efilive it shows to never go over 196°
Same results I get with HP Tuners on my truck. I have seen it creep over 200 on a few Test and Tune days but that is it.
I would be getting freaked out if the tranny went over 200. I have gotten into the low 180's a couple times after back to back to back pulls at the strip and that was really beating on it.
Old Jun 13, 2012 | 09:36 PM
  #28
Onetogofast's Avatar
Tru Cool on the way!!! Planning on using my factory trans cooler for an oil cooler since GM forgot to put one on my vehicle...
Old Jun 13, 2012 | 10:10 PM
  #29
lady3bglover's Avatar
That's right, they forgot.. I can see that happening. lmao
Old Jun 14, 2012 | 08:14 PM
  #30
All too often LOL!!!
