cleaned the truck and got some goodies!
Old 10-04-2010, 11:04 AM
fortplainman's Avatar
is the standard GM fluid synthetic? any other recommendations on non-synthetic fluid?
Old 10-04-2010, 01:04 PM
Nice truck man! Just curious but where did you get the diff cover from? You can PM me if you want.
Old 10-04-2010, 05:24 PM
jimmyboy8301's Avatar
looks good
i dont believe so
Old 10-04-2010, 07:00 PM
thanks james. sad news though, gears wont be in for ok4wd, so that probably means im not gona go. still up in the air.
Old 10-04-2010, 07:41 PM
f4tal's Avatar
Don't quote me, but i think they say not to use synthetic fluid due to the clutches on the posi. I guess it causes it to slip
I know they tell you not to run synthetic fluid in built trannys either.
Any basic GM gear oil will be fine
Old 10-04-2010, 08:03 PM
08Chevy's Avatar
just run stock fluids. They aren't sysnthetic.
Old 10-04-2010, 08:04 PM
sweet thats what i figured. was gona branch out and use royal purple instead of stock fluids, but ill just use good old GM stuff.
Old 10-04-2010, 09:08 PM
sureshot's Avatar
The Truetracs don't have clutches, they are gear driven. The Eaton LSD's have springs and cluth packs and require a special additive to the gear oil to eliminate clutch chatter.
Old 10-04-2010, 09:11 PM
f4tal's Avatar
I couldnt tell what it was. But your right about that.
Quick Reply: cleaned the truck and got some goodies!
