Cheatr V.3 in a LY5
Old Aug 27, 2010 | 05:51 PM
  #91
$ierraLY5's Avatar
Originally Posted by Preston129
Why aren't there auxiliary systems in place to backup the BOP? Would it be possible to have one or two remotely activated plates that could laterally shear the piping below the wellbore?
I don't want to get in a long discussion about it but in a nut shell, the BOP is your back-up. Your first line of defense is a good well plan, proper mud weight to give you the head pressure to hold an in-flux down. When you run casing in the well you lock the casing down, then you cement the casing. After that you test the casing and cement. ( 2nd line of defense). If that fails then you can close an annular packer on the pipe, of which we have two, or you could close a pipe ram, of which we have three ( 3rd line of defense). If that fails than you can close your shear rams and cut off the pipe. ( 4th line of defense). If that fails and you have gas in the riser now then you can close your diverter packer at the surface and divert the kick overboard. ( 5th line of defense). So we could continue to add back-ups on top of back-ups until the system is too heavy and complicated to be practical. The root of the problem is operator error. It's just like my work-mate, he has destroyed two Dana 60 differentials behind his N/A Dodge Ram 5.9L magnum. That's how humans work, you give us a system and we can find a way to break it.
robert85
Oct 3, 2012 08:43 PM
05 vortec high output
Jul 21, 2012 02:23 PM
robert85
Jul 14, 2012 11:36 PM
Oct 31, 2011 10:49 PM
skyhighsami
Oct 28, 2010 12:09 AM
